FixYa.com
Tags:
Gateway Keyboard
Gateway keyboard shift key creating special... (by 3 users)
posted by benjaed on Jan 30, 2008
I have been having the issue that every time I depress the left shift key to create a capital, I get an extra character: |S
that was one example...if I hold it down for a second or two it does this: |||||||||||||||||||||||||||||||||||||
I have not found any answers yet. Please Help. my gateway keyboard is model# KB-0401
Thanks,
|Ed
Comment by benjaed, posted on Feb 06, 2008
Now I believe that I could figure that one out myself. If you look at the original post, the character is not one found on the board for starters, and I said the specific key was causing this issue. Not the others, as I did of course test them too. This is specific to one shift and the character is not one from a key on the board. Sorry but this is not even close to the issue.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by mydogcash, posted on Feb 11, 2008
I have been having the same problem for about six months. |Has anyone tried coctacting |Gateway to see if they will replace the keyboard. |It is only the left shift key that creates the unwanted line.
Comment by jthurston, posted on Feb 01, 2008
My left shift key enters special characters when depressed. ||||||||| is an example.
Best Solution
posted on Feb 24, 2008
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have the same problem with my keyboard. It is really anoying! |||||||||||||||||||||| it is just this keyboard I think. I am going to contact Gateway for a replacement.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 05, 2008
Thanks for Trying (70)
gilheero
Rank:Wiz Wiz
Rating: 75%, 105 votes
try check some other keys, maybe its pressed down also....
Solution #3
posted on Jun 25, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I have the exact same model keyboard and this happens to me. I believe it's a WIndows driver issue, since it doesn't do it on Linux. However, I've come to live with it. It only does it when the key is held down for more than half a second (sometimes). My solution suggestion would be to convert to Linux. Not because I'm a hardcore Linux fan, and I hate everyone that uses Windows, but this is the only way to fix it.
Solution #4
posted on Apr 18, 2008
Not Rated (0)
Mazy02
Rating: 0%, 0 votes
|I have been having the same issue with this keyboard since it was fresh out of the box. Unfortunatly, I replaced it right away with an ergonomic keyboard & didn't think about replacing it. Now that the ergonomic one is busted, I'm stuck with the factory one again with the same problem. I contacted Customer Support & they told me that it was a faulty keyboard & should be replaced. So, basically, there isn't anything you can do but go out & get a new one. If you are still within the one year warrenty, Gateway will replace it for free, so you'd better test out those keyboards right away & replace them immediately if need be!
-mazy
Solution #5
posted on Apr 05, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
anyone get any answers? I have the same problem with this gateway Keyboard no matter what computer i plug it into
it happens most when you hit left shift key + any letter key at the exact same time: UUu|U|UuUuU|U|UU\UuU|U\u .... even some back slashes in there from it....
Can you Help with these Keyboards and Mice problems?
Gateway (2520915) Keyboard
Gateway cordless KR-0401...
I'm having a hard time logging... Answer This...
I cannot sync the mouse and key...
How do I sync the mouse and key... Answer This...
Shift does not work properly
Unless I pound the space bar it... Answer This...
keyboard issues
ok im useing a gateway laptop... Answer This...
cut, copy, and paste keys
The cut, copy, and paste keys... Answer This...
Repair Service
Find Keyboard and Mice Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
