My connection comes and goes - Computers & Internet
    Problem Solver:
  • 16 Answers
Need more info. Are you talking about a internet connection or a wireless. Is the connection on broadband or dial up? DSL or CABLE?
Posted on Jan 30, 2008
Model BH6820SW. Why aren't rear speakers working correctly?
  • The rear speakers may have been connected with L and R channels reversed
  • One speaker may have been connected with correct phase and one with phase reversed
  • Both speakers may have been connected with phase reversed
  • The remote may be selecting output that is not suited to your particular listening environment
Nov 30, 2015 | LG Audio Players & Recorders
Wierd beeping noise
bad seatbelt connection
Feb 05, 2018 | 1999 Dodge Caravan
Sanyo plasma tv shows no picture. Picture comes on and goes off. Sound come on and goes off.
check to see if your input signal is connected correctly. Might not be a tight connection.
May 25, 2012 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Cam senor
this is possibly a loose eleectrical connection at starter battery or alternator check tightness clean connections
Nov 10, 2011 | 1997 Mercury Sable
Tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Jan 23, 2010 | Westinghouse SK-32H240S Television
I have the Kd-S550, I need the wire connections . thanks
yellow goes to positive of the battery
red goes to the acc of the ignition(0volts whn car is off 12volts when car is on)
blue goes to a amplifier remote terminal if you have on if not the tape over the exposed copper
black goes to ground
the white of the speaker is that coming from the radio or from the car?
if it is from the radio then connect it to one side of the speaker
you need the cars radio wiring instructions and radio wiring intructions and double check each wire
Jan 03, 2010 | JVC KD-S550 CD Player
I have a ec series track light that has a white and black wire coming out of it. I also have a ceiling box that has a red, black and white wire coming out of it. They are to be on a dual dimmer switch that...
The light track series, just connect them in each side of the special plug in connection for the bulb, for the dual dimmer the red goes to red, the white goes to yellow and the black goes to black
Oct 30, 2009 | Hampton Bay Dryers
How to wire a 3 phace 5 hp baldor motor
the neutral or white is not used. if the fourth wire is a ground then it goes to the motor frame. if it is a dual voltage motor then here is the wiring: for 240 volt 3 phase connect 4-5-6 together and tape, 3-9 goes on L1, 2-8 together goes on L2, 1-7 together goes on L3. To reverse direction swap any two line wires. For 480 volts 3 phase: L1 goes on T1, L2 goes on T2, L3 goes on T3. Connect together T6-T9 and tape, connect T5-T8 and tape, connect T4-T7 and tape. again to reverse direction swap two line wires.
Oct 14, 2009 | Baldor 115v,1ph, 3,600rpm 7" 1/2hpbnch...
Monitor doesnt come on , but the power light goes from amber to green. then comes on after 20-30mins maybe.
Maybe update your display drivers. PC appears to be slow.
Make sure you don't have a bunch of apps that auto start.
Do you hibenate your PC?
Same issue if you connect monitor to another PC?
If issue follows you to a different PC it says monitor. If it doesn't it says the first PC (that monitor is currently connected to) had a cpu/memory or a driver issue.
Good luck
Oct 25, 2017 | Sony SDM-HX93 19" LCD Monitor
Computers & Internet Logo
41 people viewed this question
Alun Cox
David Payne
David Payne
