Question about Sony Cyber-Shot DSC-P92 Digital Camera
Not turning on
I haven't used this camera in over a year, but I put new batteries in and pressing the POWER button yields about a one-second green light and it automatically shuts off. In the VIEW mode, it turns on so I can scroll through pictures previously taken, but any other option/function only gives me the one-second green ON light and shuts off. Is this something to do with a malfunctioning shutter or another reason?
Any help would be greatly appreciated.
I have the same issue, no noises or grinding. Could it be an internal battery used to store the date and time going dead?
Posted on Feb 02, 2008
    Scholar:
  • 32 Answers
You might be on the right track here, I can usually tell if machinery is a problem like this. When you turn on the camera to a position that would turn it off, does the camera make any sounds? gears or clicking sounds can point to a shutter or other mechanical issue, If there are none, then there is a possibility that there could be a firmware issue with the camera and you may need to contact the vendor for a service order. mechanical issues are increasingly difficult for the layman to repair, and putting one of these technological wonders back together can be an ordeal all its own.
The short answer here is simple. Find out if it is mechanical, then call customer support. Compare the price of a repair with the price of a shiny new camera.
Posted on Jan 30, 2008
HELP ME PLEASE!
Option 1. Just take the back off and then take the battery out. Put it back in and put the back on. Press the power button until you see the green android thing then let go. It should turn on.
Option . Held the volume down button down then while continuing to hold it down. Hold down the power button and nothing happened after about 45 seconds so just let go off the buttons
Option 3
1.Power off the phone.
2.Press and hold Vol+ key and Power key simultaneously for about 10 seconds until the some option appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.
3.Use Vol+ key and Vol- key to move the cursor to "wipe cache partition" and press camera key to confirm it.
4.After 5 seconds, the cursor will be on "reboot system now" again and press camera key to confirm it. The phone will reboot automatically,, you need back up all the datas and contacts to SD card before performing reset on your device this method will delete all the datas and contacts.
Jul 19, 2013 | Boost Mobile ZTE Warp Sequent Touchscreen...
Camcorder wont turn on at all
Are the batteries fully charged ?
Jun 17, 2017 | Mitsuba DV777 Camcorder
Wont turn on, new batteries, green light just blinks.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds.
A blinking light can mean something is wrong with the power, not enough or something else.
If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
Oct 20, 2009 | Samsung S860 Digital Camera
My sony cybershot dcs-s700, it has new batteries, but the power button flashes green and camera will not stay on, and you are unable to magnify. Whats wrong
Hi!
Remove the Battery from the Camera and clean the battery compartment using a soft cloth. Then, press and hold the power button for 30 seconds. Then, reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery is fully charged. If the issue persists then the issue may be related to mechanical failure and service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
I cannot activate Nikon Coolpix S210 (problem with ON/OFF button)
had a similar issue with my Pentax, it would power on and power back off. Tried playing with it for a while and it never recovered. Chances are its time to replace it. These new electronics are jam packed with lots of mini moving parts and are prone to excessive wear over time. they're are no servicable parts inside them unfortunately. I would try ebay for a reasonable replacement camera.
Aug 06, 2009 | Nikon Coolpix S210 Digital Camera
Power on n off
sounds like a battery power problem or problem with the terminal of the camera ; you know the point where the battery meets the camera.
I would recommend a service center
May 31, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Lense not closing, switching on for one second then shuts down. when attempting to turn on green light flashes then turns off
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 21, 2008 | Canon Cameras
Unable to take Pictures
So, you're using Ni-MH batteries already, once you've turned it on and then you have to press on the PLAY button to view pictures, i need you to double check the battery type option of your camera by doing the steps below:
- Press MENU
- Scroll to the right until you are in SETUP 2
- Go down to Battery Type
- Switch it over to Ni-MH (for Rechargeable batteries)
- Select Alkaline (for Non-rechargeable batteries)
- Press MENU/OK for changes to be saved
Turn off camera for a few seconds so settings will be refreshed.
Turn on camera without pressing on the PLAY button to double check if it works.
If it does not work still, try to turn on again camera and immediately press on PLAY button to view pictures. Try to press again on PLAY button so you'll be on the mode to
take a picture.
If it still does not work, can you please try Non-rechargeable batteries (Alkaline) with your camera if it won't work with the Nickel-metal Hydride (Ni-MH) Rechargeable batteries.
Make sure you have set properly the battery type of the camera under SETUP 2 for Alkaline.
take a picture.
If it still won't work, then you have to send the camera for Repair.
Register camera online:
- Go to www.samsungcamerausa.com
- Click on Customer Service
- Register under Option 2 Box
- Fill out the required info
- Read instructions
- If website asked you to upload a receipt, just skip that
step and leave it blank
- Take note of the ASC address and online ticket number
that will be generated at the last step
- Turn-Around-Time will be 7-14 business days
Do the following:
- Include a copy of receipt in the box to avail of the warranty
- If you don't have any receipt, include a copy of credit/debit card statement/cancelled check that was used to purchase the camera
- Exclude all accessories when sending camera for repair
(No batteries, memory card, strap, cables, manual, CD)
- Write the online ticket number on top of the box
- Use another box and sealed it properly to avoid damages during shipment
- Check repair status using Online your zip code and phone number as you proceed on the Repair status of the website
Sep 14, 2007 | Samsung Digimax S630 Digital Camera
The camera will not power up with new batteries installed.
This happened to me too. I did some research and if you were using anything other than alkaline or NIMH batteries (I was using Nicd rechargables) it will fry the circuit board. That's Sony's way of making sure you use their rechargable batteries only (or buying costly alkaline). Our cameras are fried. Time for a new one.
Apr 20, 2007 | Sony Cyber-Shot DSC-W5 Digital Camera
Sony Cyber-Shot DSC-P92 Digital Camera Logo
37 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
