Question about RCA P52937 52" Rear Projection Television
RCA Home Theater Premiere
TV: RCA Home Theater Premiere
Mod: P52930BL
Ser: 826351167
Chassis: PTK195EB June 1998
Service: P52930BL-YX1
Problem: TV has no sound and/or has static when watching just the TV, but watching a DVD, sound is perfect. Apparently, there was some sort of recall on this tv which fixed this re-occuring problem, but it seems to be doing it again. The tv is obviously out of warranty now, is this problem minor and worth fixing?
Thanks,
Sappy.
  • 2 more comments
  • Anonymous Sep 26, 2008
    How fix the sound.
  • bpreciado Dec 01, 2008
    I have a RCA Home Theater TV I bought about four years ago, until recently we had it hooked to a cable box, now that we don't have it hooked to a cable box anymore, the channels won't turn, it is stuck on channel 2, does anyone know how to make it work without a cable box?
  • Anonymous Mar 12, 2009
    Sound at times just goes to static. Unplugging always fixes this so far. Figure it is a capacitor problem!!
  • Tammy Rollings May 01, 2009
    I have the same NO SOUND problem...but at the same time the sound went a royal blue tint showed up around some objects in the picture....Can anyone help??
    New Friend:
  • 20 Answers
Unplug the TV for 4 hrs. and let it reset to factory settings and then start from there scan for channel line up in the menu.
Posted on Jan 23, 2010
SOMETIMES I CAN TURN MY TV ON, AND SOUND IS WORKING FINE. SOMETIMES I TURN IT ON AND THE PICTURE SHOWS GREAT, BUT NO SOUND
Posted on Feb 05, 2008
I have problem with the sound
Posted on Oct 22, 2008
    President:
  • 4,402 Answers
When the unit is unplugged and replugged, it empties these registers of the corrupt data.
fix is to place a 1mfd capacitor to ground on U13101 pin (15). This
swamps the closed caption data to the micro and stops the reception of
the defective data packet. In the event that later on the resolve the
defective data problem the capacitor can be removed. the close
caption feature will not work with this cap. installed
or
have it fixed click here
Posted on Jan 30, 2008
6ya staff
SOURCE:
I have 2 RCA 52" projection TV's. One has a
dale_earn387,
RCA always has the part number stamped on the board. It will be a six digit number and usually is preceeded by "P/N". I have worked on these units and would guess that many of the boards are the same. Check the part numbers and if they are the same and the physical layout of the board looks the same the boards should be interchangable. I could not determine through research if the parts are the same because the units are older. I did determine that the CRTs are identical which would mean that more than likely the control signal board for them will also work.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 19, 2011 | RCA P52921 52" Rear Projection Television
I need help , hooking up my samsung HT-Z410 HOME THEATER, TO MY LG HDTV, SO THAT WHEN I'M WATCHING REGULAR TV THE SOUND OF THE TV CAN COME OUT TRUE THE HOME THEATER SPEAKERS, CAN IT BE DONE? CAN A COMCAST...
first of all here is a link to the manual....http://downloadcenter.samsung.com/content/UM/200802/20080220095448484_HT-Z410-XAA.pdf and yes it can be conected thru your comcast but you wil need to buy probably cheapest at wallmart an RF Modulator (Less than 20 dollars) and from your cable box (vidieo out, or to tv) install the cable to the rf mod unit (ant in) and that converts it from coaxial cable to rca (meaning a cord with yellow ,red,white push on connectors) plug the red and white into aux input on surround system (see #3 on manual view on backside of surround unit)and and you got it.It your tv does not have a yellow vidieo connection (which is where the the yellow plug into tv)in the back then add a coaxial splitter after the comcast box so that the 1 coax line goes to tv and the other coax goes to the rf mod then thru RCA cables to the surround sound.you may need to buy xtra cables but they are cheap. hope i helped........you may try asking family or friends for the above equipment i described.the newer tv's dont need it and many people have this stuff layen around...good look
Jan 18, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
RCA Home Theater Premiere 36" TV comes on automatically
Only two possible reasons I can think of for this--
ONE: you have looked in the customer menu and there is no item listed as Timer?
TWO: Does THIS SET HAVE THE GUIDE PLUS LOGO ON THE FRONT OF THE SET? IF IT HAS THE GUIDE PLUS--YOU WILL FIND IT IN THE MENU ALSO---
LET me know if it has the guide plus feature and I can tell you how to end the problem--most of these the set will come on at the same odd time and usually with volume up high.
SD TECH
Dec 26, 2009 | RCA P52937 52" Rear Projection Television
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
Aug 09, 2009 | Samsung Theater System
Channel banner burned into display
All three color lenses may need replaced and if thats the case you might want to consider buying another tv
Dec 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca home theater tv guide plus mod#p52820BL
Can you try using a different video cable?
May 08, 2008 | Televison & Video
RCA 52" Rear Projection P52930BL
You can adj. from the front panel of the set using the channel and vol. buttons,if the set you have has a ptk 195 chassis,check and make sure you have adj. projection tv in screens of the menu,in not the convergence power supply has failed,replace the reg on the board,part number is 215530
Oct 04, 2007 | RCA P52930BL 52" Rear Projection...
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
Sound Fades, then TV shuts off then continues to recycle on & off
Sometims several capacitors start going bad giving you the audio problem, but I don't remember the set turning itself off. That could be a secondary problem around the flyback transformer which may have a bad solder connection. I would check that first. Otherwise, I would be tempted to go with HDTV.
May 29, 2007 | RCA F36685 36" TV
When TV warms up, the sound is scratchy and the image turns snowy, but everything works fine with the DVD player even when warm. the TV works fine when you just turn it on it just happens when it warms up...
You have already diagnosed the tuner as the problem,the first thing to check is the conections at the tuner specially the ground conections,the shell of the tuner is the ground and it conects to the chassis by being solder to it,if all conections check ok look for overheated areas.After that is taken care you still have the possibility of having a bad tuner.If you are familiar with tv service this information will help but if you are not too familiar be safe and call for assistance from a servicer.
Oct 03, 2006 | RCA P52930BL 52" Rear Projection...
RCA P52937 52" Rear Projection Television Logo
2,303 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
