I have a Samsung LN-T4661F that has recently started to make a clicking noise when the power is first turned on after being off all night. It takes about 1 to 3 mins for the tv to turn on. Any help would be great as the tv isnt really that old.
hi this could be a tab/ribbon fault, there are ribbons attach to the screen at the top there's chips installed on them. when one is faulty they heat up and make the ribbon start to flex and move causing this fault, hope it helps
unfortunately there is no way to fix this short of taking the unit apart and checking for loose connections, which may cause more problems than it solves, either take it to a tv repairman or hope it doesnt get any worse :s
good day .maybe theres a defect in the board causing the screen changes abnormally. maybe the screen module is defective. just consult that problem to samsung service center to fix your problem.
Hello: Your problem is in the power supply, there are two 2200UF 10volt capacitors in the upper right corner of the power supply that are leaky. The Capacitors supply power to the System Control board and other various parts to the television. You can replaced these your self if you have a mind to and is some what electricaly inclined. These should be replaced with 16v caps instead. If you decide to repair it yourself, after taking the back off, the power supply is generally in the middle of the unit, you will have to remove a metal sheilding paned from over it and look in the upper right side of the board the capacitors should be obvious as they are bulgeing on the top they are right next to each other, They carry 5v to video brd and other parts...
If you need more assistance, Then email me at [email protected]
or phone me at: 702-418-1389
