Question about Symphonic ST419E TV
Tuning problem with tv connect directly to cable tv input, I am unable to tune channels above channel 25. Other TV's tune higher channels OK.
  • rrsharpe Jan 30, 2008
    I think it's fixed....however I won't be able to test it until later tonight. Will report then.
  • rrsharpe Jan 31, 2008
    It was a simple problem and solution, but, given the complexity of the Symphonic menu system ..... it was not at all obvious. Thanks for your expert help.
  • 86 Answers
Your TV is set to Antenna. You need to go into the menu and change it to Cable. Then do an autoprogram.
Posted on Jan 30, 2008
Unable to tune into any channels
It's much more likely to be the antenna. How old is the TV? Check whether the antenna connection is loose. Check whether the antenna cabling is all connected. Did anything change just before the TV stopped working, like someone doing work outside? If you're receiving cable TV check the connections to and from the cable box.
Nov 16, 2013 | GPS
Toshiba TV, I can't tune channels, when I go to
Check whether the input is selected to AV. In AV mode, no tuning is possible. It it is in this mode now, switch it to TV mode.
Jan 13, 2013 | Televison & Video
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
My sharp 25n-m100 only gets a couple of the cable channels how do i make it get all basic cable channels
In the menu look for an ANT INPUT option, choose cable and look for an AUTO TUNE option. Hit the AUTO TUNE and wait til it scans all the available channels.
Dec 24, 2010 | Sharp 25N-M100 25" TV
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
Programming Channels
Your TV is likely set for "AIR" tuning rather than "CABLE" mode. In this case channels above 13 don't tune correctly. The tuning mode is adjusted through the setup menu (it's been too long since I've seen one of these to remember exactly how the menu looks). Once you set the tuning mode for cable, all the available channels should come in properly.
But you've said you have satellite, so you should have a satellite receiver connected to your TV, and you'd be changing channels there rather than on the TV. Your TV would be staying on channel 3 or 4 (if using the satellite antenna output connection), or on the A/V input you have the satellite connected to (if using the direct A/V outputs). Am I missing something about your system?
Feb 18, 2009 | Mitsubishi WS-73905 73" Rear Projection...
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Am I connecting DVD player wrong?
on some of these older RCA try simply tuning it from the remote down to chanel 01 or 00 this may work. if not you have to go into the setup menu of this set and enable the aux inputs
Feb 19, 2008 | GE 25GT240 25" TV
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
VCR tuner cannot tune in my cable channels
It is working as designed. The purpose of your cable box is to take in a wire containing all of the possible channels you might watch, and then extract *one* channel, and force it to appear as channel 3. If you connect the cable directly to the VCR, then the VCR's "tuner" (ie, channel selector) has an opportunity to extract any channel it wants. But... as you point out, your VCR won't be able to "see" any of the digital channels. So... if your goal is to be able to watch any of the digital channels, the signal must pass through your cable box, which will put the selected channel on channel 3. There is no value in going from the VCR to the cable box, since the VCR's tuner will have already filtered out all but one channel. It would be helpful to make a list of what your useage goals really are, since there are so many different ways to hook these things up. Are you interested in: - watching digital channels? - recording digital channels? - watching one channel while recording another? - using higher quality video signals (composite, s-video, component, etc) rather than RF (ie, channel 3) And so on. Keep in mind that you have *three* tuners: Your cable box, your VCR, and your TV. It sounds like only your cable box can tune in the digital channels. If your cable box puts out any non-RF signal, then the best choice would be to go: Coaxial Wire -> Cable Box -> Video Connection -> VCR -> Video Connection -> TV, with the VCR and the TV both set to "video". Then you would only use the cable box as a tuner, the VCR would only see the tuned channel (via video in), and the TV would see the same channel (or whatever tape you are playing) on its video input.
Mar 29, 2007 | Zenith VCS442 VHS VCR
Symphonic ST419E TV Logo
331 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
