Question about Maytag PYE2300AY Electric Dryer
MAYTAG Heat Element Shield?
Until a week ago, I had never worked on or even seen the inside of a dryer before. The tumbler stopped working on my Maytag Performa PYET244AYW, but I still had heat blowing. I figured it was a broken belt.
I attempted to find my way into the dryer, starting in the back undoing screws. I also tilted the dryer forward to look for screws on the bottom, heard a clanging sound from a piece of metal falling inside the dryer, then put it back on it's feet.
Getting nowhere fast, I got on the internet and found out how to really get into the dryer from the front. I lifted the top and removed the front after disconnecting the switch. The belt was broken.
Ever since I've owned the dryer, over 4 years now, it has made a loud rumbling noise while running, but I never investigated. I pulled out the tumbler drum and now know where the noise came from. One of the rear drum rollers had the rubber tread worn completely off. I also realized that I had unscrewed the back panel earlier, so I screwed it back in. I also found the piece of metal that fell. It's 8" long x 2.5" wide, bent sort of like an "M", and has 2 screw holes.
I ordered up the replacement parts, installed them, vacuumed the inside, and put the dryer back together. I didn't know what the piece of metal was, so I guessed it was a heat element shield, so that the high limit thermostat wouldn't be exposed to the coils and that's where I put it, over the coils.
I fired up the dryer and the tumbler drum was turning again, quietly, but then I think I heard some crackling and saw a couple of blue flashes of light. The heat stopped working. I opened the top back up again, looked around, removed the metal plate, and noticed the heat element broke completely off, about an inch away from the contact clips.
I bought a new heat element today, installed it, and tested it without putting the metal plate back on top and it works fine. My questions are: What is the metal plate for and did I short out the heat element with it? If it's not a heat shield, should the heat element coils just be exposed like that? Is it safe for me to use my dryer again?
Thanks,
Rob
  • RobDude Feb 01, 2008
    I disagree as the metal plate actually shorted the heat element out. There's 2 notches burnt into the plate from the heat element. And only a one sentence reply after all the typing I did? Please try again.
    President:
  • 1,314 Answers
Not really put the plate back on it helps force the air across and keeps lint out
Posted on Jan 30, 2008
  • robert samples Feb 01, 2008
    sorry guy the question didn't require gone with the wind the shield didn't short the element the element broke and touched the shield you can believe one thing if the shield didn't need to be there the appliance company's wouldn't put it there they count screws to see where they can skip one lol
Need to convert electrical Maytag Performa Dryer (Model:PYET244AYW) to propane gas system. It can be converted?
No that can not be done fairly inexpensivly...it could be converted but would actually cost more to purchase all needed parts that it would be to buy a brand new gas dryer
Oct 16, 2011 | Maytag PYE2300AY Electric Dryer
My Maytag Dryer DE608.. does not get any heat. It worked great 2 days ago.
heat element can be bad. you can fine heat element inside at the back of the tumbler
Oct 15, 2010 | Maytag Washing Machines
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
Squeaking Noise coming from Dryer
Could be the roller next to the heating element. Heat tends to cause more wear in it. Use some HVAC oil to lube those noisy rollers. 6b5c930.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 02, 2010 | Maytag PYE2300AY Electric Dryer
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
Maytag performa pav2200 dryer has stopped heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
tust
Jan 24, 2010 | Maytag Performa PAV2200
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
Dryer makes clunking noise when it starts and stops. Also noisy during the drying cycle. It's a Maytag
May need a new blower wheel.
The wheel is mounted to the motor and if it is stripped out it will not move air past the heat element.
Have it checked before the heat element fails.
Jan 16, 2010 | LG DLE2515S Gas Dryer
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
Maytag PYE2300AY Electric Dryer Logo
284 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
