2001 BMW Z3 Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for spark plug torque specification for 2001 bmw z3 2.5l roadster
Anonymous
Level 3:
  • Master 510 Answers
  • Posted on Dec 30, 2009
Anonymous
Master
Level 3:
Answers
510
Questions
0
Helped
384405
Points
1812
Anonymous
Level 3:
Brigadier General:
  • Master 7,353 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
7353
Questions
Helped
2487696
Points
23804
25 nm or 18 ft lbs.
3answers
1helpful
What is the specific torque for the sparks plugs for Nissan Tiida 1.8L 2011
There is no specific torque for spark plugs. Simply tighten them down nice and snug with a 3/8 ratchet not a 1/2 ratchet. You may over tighten them with a 1/2 ratchet!
What are the spark plug torque Specs on a 95 Honda Civic LX 1.5 liter.
Torque Chart - E3 Spark Plugs
e3sparkplugs.com/torque-chart/
The table below lists the torquing specifications for most spark plugs being installed in either cast iron or aluminum cylinder heads. Torque values assume clean, dry threads.
Tech Specs - Spark Plug Cross Reference, Torque ... - Autolite
1helpful
What is the head bolt torque sequence on a 1998 BMW Z3 Roadster 2.8 liter?
Its usually from the center out in the next most opposite bolt (star) sequence. ie. if its a 14 bolt head 1-7 top, 8-14 both from front it would be like 4-11-3-12-5-10-6-9-2-13-6-8-1-14-7. you just want to avoid tightening a bolt outside a non torqued bolt to prevent head or gasket damage. torque specs are done in degrees, ie 44 ft/lbs, then run it 15 min then tighten another 33 degrees, then run it another 10 minutes and final torque another 25 degrees.
2helpful
2001 bmw 525i wont start cranks but wont start
You should try removing the spark plugs and going over the end with some sandpaper. The problem may be something else completely, but sometimes the ends get a little dull and they don't 'spark' as well as they should. Be careful though - only remove them if you have a torque and you can tighten them up again at the required torque setting.
if you are facing this only under cold condition please do say it . i will say whats the problem there.
2001 bmw 325i changing spark plugs
it doesant sound like its a problem from your spark plugs sounds more like a stepper motor problem make sure you have fitted everthing correctly after you have changed spark plugs sensors ect if you needed to remove elctrical sensors
Faulty torque lock up in 4th gear
I would say either  transmission control module or the torque converter.
How do you replace the waterpump on a bmw z3 2.2
3.0 Coupe
Removing and installing complete water pump (M52 / S52 /M52TU/ M54 / M56)
Remove alternator
drive belt, refer to Engine, Cooling and Exhaust - Engine - Drive Belts, Mounts, Brackets and Accessories - Drive Belt - Service and Repair - Procedures See: Engine\Drive Belt\Service and Repair
Note: M52/S52 The water drain plug is located on the exhaust side between cylinders 4 and 5 in the engine block (illustration).
M52TU / M54 / M56 The water drain plug is located on the exhaust side on cylinder 2 in the engine block.
Drain and dispose of coolant.
Installation:
Replace seal.
Tightening Torque, refer to Specifications - Mechanical. See: Specifications
Vent cooling system and check for leaks, refer to Engine, Cooling and Exhaust - Cooling System - Service and Repair - Procedures. See: Service and Repair
Release belt pulley,Release water pump.,Tighten two screws (M6) into thread of water pump and water pump out of timing case.
Installation:
Replace O-ring and coat with coolant as anti-friction agent.
2.5L Roadster
SAME PROCEDURE FOR PICTURES Email Me @ aol.com
Feb 21, 2009 • 2001 BMW Z3
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
