Without a schema all i can suggest is to check the rectifier bridge assemblies (ohms check or diode test) one of them might be shorted, you do not have to turn the tv on to do further circuit checking.
I have worked on about 5500 projectors in the past 10 years.
There is a dead short already somewhere so you cant blow anything else up if its a fast blow fuse.
Disconnect the Convergence Amp from the pwr sply then power it up for a few seconds with your 4amp fuse. Does the fuse still blow? If so, check the HOT transistor. (3 pin chip againts the largest heat sink)
Good luck
