Question about Car Audio & Video
Only have 1 remote wire for aerial
Hit there
I have recently learnt that my pioneer head unit has only 1 remote wire for aerial/subs. Therefore when the car is on the aerial will always stay up even when i am listening t a cd.. is htere anyway to solve this.. and what will happen when i need to put the subs back in the car how will this work?
  • 86 Answers
Hello simple ..just put a on/off switch inline with you aerial power lead ..amps will stay on ..if you dont want the aerial up .just flickm the switch off..down it goes
Posted on Feb 12, 2008
I am putting an external amp to run my subs and i need to know where to hook my remote wire to from the back of the deck
Norrmally the head unit/deck has a blue wire for the remote in the Pioneer set. So check this out and use a meter to see for voltage when the head set is switched on. Now you can connecct this as the remote swiching required for your amplifier. hope you look into the back side of the head unit ,in the cluster wire from the connectors. Good day
Aug 15, 2010 | Pioneer DEH-1500 CD Player
Hi I'm having a few issues with my deh 2100 head unit in my VY commodore. I installed it myself with the right wiring harness but the head unit doesn't remember settings or band settings. Also when the...
When a head unit doesn't remember settings like yours, then the Yellow constant battery wire isn't hooked up correctly. This wire provides power to your unit constantly from the battery so that it can remember the settings and such. Your aerial not going up is the Blue power antenna wire. This wire will provide power so that when you turn your unit on, it powers the antenna to go up. Hope this helps!
Aug 05, 2010 | Pioneer DEH-2100 CD Player
Deh-9300 remote on wire ground
There is an internal relay that switches the amplifier remote turn on from ground to 12VDC when the ignition (ACC) wire is applied power.
The internal relay (inside the radio) is faulty and must be repaired.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 30, 2010 | Pioneer GM-7100M Car Audio Amplifier
How to install car stereo with an amplifier and equalizer
power wire from batt fused to positive on amp .earth wire eg - to bare metal in car with bolt or screw. remote wire from amp to remote wire on back of head unit mostly blue wire it tells amp when to turn on then you need a set of rca cables to send sound from head unit to amp they go in subout if you wanna use sub or rear or front out for full sound best thing is to buy amp kit cheaper most the time and all you need there hope this helps
Oct 23, 2009 | Pioneer GM-D7400M Car Audio Amplifier
Amp not staying on
Hello lyttle_matt1,
Connect a DC voltmeter between the "remote" (+) terminal and the "ground" (-) terminal on the amp. When you turn on your Pioneer, you should read 12-14V. If you get voltage for a second and then it goes away, either the incorrect wire from the head unit is connected, or the head unit remote turn-on is defective. If the voltage remains on the terminal and the amp immediately turns back off, it's possible that the remote turn-on is not supplying adequate current for the amp. To determine if that is the case, run a separate wire from a positive (+) accessory terminal (cigarette lighter or fuse box) to the amp remote terminal. If the amp then turns on and stays on, you'll need to wire a relay into the turn-on wire. The wiring for such a relay is shown here. Most any 12V SPST or SPDT relay from an auto parts store or Radio Shack will work OK.
May 11, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
My pioneer head unit cuts the audio signal to my speakers
3 things make sure all the speakers in the car have tape to avoid grounding the speakers
next make sure all wires in back of unit are taped
if all that is taped good its the amp over loading use a larger ground wire to fix this
hope this helped
Feb 25, 2009 | Pioneer DEH-P4000UB CD Player
Can't fit subwoofer amp leads to pioneer DEH-2000MP Head unit
pioneer head units only distribute like 200 rms or so to the speakers. you might have to find a blue maybe even blue with white striped wire and nick it just enough to tie your amp wire around it. tape it up and see if it works.
Feb 24, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
How do i turn on sub mode?
For one thing I hope you know you need an amp to even power subs at all.. The remote wire coming off the rca wiring that you hook your subs up with has to go on the prong 3-in on the top here is a rough diagram: the = signs are power and ground and the prongs are thicker the comma is you remote..
You need a wire coming out of that slot on the wiring harness.. it should be blue. and unless you have a power antenna(comes out when you turn your radio on) then you dont need the blue/blue&white power ant. wire you can just cut it and cap it. if your amp isn't coming on when you turn your ignition to acc then your remote wire isn't properly attached..
May 15, 2008 | Pioneer DEH-P4700MP CD Player
I have a pioneer gm-x404
The wiring is fairly straight forward. Along the top row of the ten pin plug =
(Left to Right)
Front Left positive,
Front left Negative,
Control wire from your stereo head unit should be thin blue wire sometimes listed as Remote Wire this switches your amp on and off via your head unit so you don't run your battery flat,
Front Right Negative,
Front Right Positive.
Bottom Row=(Left to Right)
Left Back Positive,
Left Back Negative
Centre Nothing
Right Back Negative
Right Back Positive
These are all inputs from your head unit.
To bridge from 4 channel to 2 you connect
one left speaker to Ch B Left Positive and Ch A Left Negative
one Right speaker to Ch B Right Negative and Ch A Right Positive
Ten Switching the Input Select switch to 2CH
Alternatively if your unit has RCA's on the back of the Head unit you can use them to run your subs.
Hope that helps.
Feb 28, 2008 | Pioneer GM-X4 Car Audio Amplifier
Pioneer DEH-225 Car Audio
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
Oct 07, 2007 | Pioneer DEH-225 CD Changer
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
