Question about Apple iPod MA446LL/A MP3 Player
Ipod wont respond/frozen thingy
Umm, hi, my 80 gig ipod seems to freeze alot when im playin music randomly and im unable to get it to respond untill it runs out of power... also, it freezes when its turned off too... any idea's how to fix this? please respond
    Problem Solver:
  • 16 Answers
Try resetting to defaults and then updating to the latest software then download your music after that.
Posted on Jan 30, 2008
6ya staff
SOURCE:
My ipod 120GB can only load 20% of my 1000songs befor freezing I did all that iTunes Trouble shooter said but to no avail. is their a way to fix this without sending it in or should i **** can my po
It will probably take an hour or two to sync 20 gigs of music.
I am sure your 4,178 songs are somewhere around 20 gig.
It takes roughly 6 - 8 hours to put 80 gig on.
Imagine how long it took to put my 130 gigs on.
Word of advice, make sure you turn the settings to manually manage music.
You don't want to lose all your music cause you hook it up to another computer and it syncs with its itunes.
installing more computer ram might be an option
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
also check the usb leads for secure dust free connections
if you scroll to the bottom toolbar while syncing your ipod select task manager application to see whats running if you see something running that should not be running select end now also in the applications see whats ticking over
you might have a virus
To disable automatic updating:
1. Connect iPod to your computer
2. Open iTunes.
3. Select iPod in the iTunes source list, you know in that left column where your playlists and ipod are located.
4. right click on your ipod and select the Options button.
5. Select "Manually manage songs and playlists."
No more long updating each time you connect your ipod.
(Although you might have to wait one more time to do this step but im sure you can do it intermittedly while its updating)
to re enable
1 - Select the iPod in iTunes.
2 - Tick Manually manage music and videos.
3 - Select the Music under Library at the top left of iTunes.
4 - Reselect the iPod and uncheck Manually manage music.
Also, uncheck Enable disk use.
Also remember in the Manange you own tracks mode you need to disconnect your ipod by clicking on the "eject ipod" icon in the bottom right or next to your ipod icon.
The ipod will continue to flash "do not disconnect" if you don't click the eject icon.
Not that my way is hard but there might be a quicker and easier way to load tracks in your ipod when its switched to the manange your own tracks mode.
If there is I would like to know
hope this helps
Oct 03, 2012 | Audio Players & Recorders
My 80 gig ipod wont power up or do anything
slide hold switch on and off a couple of times and leave the switch to off position.the press and hold menu and centre buttons till an apple logo appears on screen.connect to itunes and use the restore option to restore your ipod.
Aug 11, 2009 | Apple iPod classic MP3 Player
It wont download music and it keeps on freezing alot cannot get to owrk when is plugged in will not respond at all
just plug in into the computer and REFORMAT it, go to MY COMPUTER and "right click" your mp4 then click FORMAT, choose the quick format system
Nov 15, 2008 | Apple iPod nano
Frozen on start up screen
my 80 gig jest wont go past a blank screen
Oct 21, 2008 | Apple iPod MA446LL/A MP3 Player
Hellllp!
Why don't you use the Itunes do transfer music?
www.apple.com/itunes/download
May 26, 2008 | Apple iPod classic MP3 Player
Computer freezes
hi
can you give more information on which program you're using for playing DVD movie ??
takecare.
May 23, 2008 | HP Pavilion zd8000 Notebook
Sad face on 80 gig cant restart
You can try going into iPod Diagnostics
Just click and hold on the Home and Center button at the same time until the screen turns black, then click and hold on the Center button and the Rewind button (Left button) until something different than a iPod display comes out.
Hope this helps!
Nicholas
Jan 26, 2008 | Apple iPod MA446LL/A MP3 Player
Motorola Razr microSD problem
scan your with norton for hidden virus !! used nokia music transfer or Nero
Dec 15, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Gigabeat frozen!
Hi Lorna, Yeah I found my Gigabeat froze a few different times when I was getting used to it. Solution: at the bottom of player there is a little battery on/off switch - its tiny and black but you would have needed to switch it on to first use it. Well turn it off here for 10 seconds and the on again. This removes all power from the hard drive and circuits which occassionally freeze. Hope that helps
Apr 23, 2007 | Toshiba gigabeat S MP3 Player
My ipod nano wont do anything
umm im not sure if this will work but you could try holding menu center button untill the apple comes up (this may not work if ipod has not got any power to run)
Feb 22, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
70 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
