Question about Dryers
Bosch Tumble Dryer Filter Light
During the drying cycle the dryer stops with the filter light on. This happens when the filter is clean. Any advice appreciated.
  • Anonymous Jul 27, 2008
    I have an electric Frigidaire dryer and my dryer stops and the clean lint filter light comes on. Is there a clog somewhere? My filter is clean.
    Novelist:
  • 130 Answers
Helenhjb, there is a couple of things I can think of that can cause this. The filter is one. The mesh on the filter is extremely fine, so get a steady stream of water running, then put the filter under the water. If the water doesn't run straight thru, then wash the filter with detergent until the water does run straight thru. If this works fine, then your issue may be that the door switch is set too far back and when you do heavy loads, the laundry pushes on the door and shuts down the dryer. On the Bosch, any time you open the door during the cycle, it will flash the lint filter lamp. The only other thing I know of usually has an E:01 flashing on the display is restricted vent. Hope this helps.
Posted on Feb 03, 2008
6ya staff
SOURCE:
Where is the filter on tumble dryer AWZ241
Hi Angie, The filter is at the back right in the middle, You pull the cover off and clean off the lint.........CHEERS..
Apr 27, 2016 | Electrolux IQ-Touch EIMED55IIW 27"...
Clean filter
If this is a condenser dryer, it could be the condenser unit that needs cleaning
Dec 21, 2013 | Siemens Dryers
Why have my dryer stop getting hot to dry clothes?
call an electrician to test the element or if gas call a gas fitter to check the gas operation
May 16, 2017 | Bosch Nexxt WTMC 3300 Electric Dryer
Hi, My 8kg Hoover Tumble dryer Vision HD stopped working, first a filter care light, so cleaned the filters and now the light comes on but nothing happens. Any ideas? Thanks Matt
try drying the inside of where the water reservoir is.also water may be collecting in a hole on the base of the condeser hosing.
Jan 08, 2011 | Hoover Dryers
CLEAN FILTER LIGHT REMAINS ON ALL THE TIME, I HAVE CLEANED FILTER, PROBLEM STILL PERSISTS. i HAVE ALSO CHANGED THE DOOR CATCH AS THIS APPEARED DIFFICULT TO CLOSE.
Hi, My Hotpoint Aquarius TCD32 0771200901
Tumble dryer stopped working, first a filter care light, so cleaned the filter and now the light comes on but nothing happens. Any ideas? Thanks
Dec 17, 2010 | Hotpoint TDC32 Electric Dryer
Warning signal "linter filter" comes on and dryer
You don't have very much information here to give you a better diagnosis, like the model or the error code, but I'll take a shot at it. If you're thinking that the flashing list filter light is the error code you can relax. The lint filter light ALWAYS flashes at the end of a cycle or before you hit the start button to begin a cycle. This is just a reminder to check the filter.
If your dyer is displaying an E:01 code this indicates blockage in the venting system. Do the simple thing 1st. wash your lint filter with some dish soap and running water, lightly scrubbing it with your finger tips. After rinsing clean pat the filter dry and re install it in the dryer. While you have the filter out look down in the filter holder area and see if you have lint built up there. They make brushes for cleaning this area or you can use a vacuum cleaner attachment to reach in there and **** out the lint.
If you still have an E:01 error after doing all this you may need to have your house vent pipe cleaned. But before you do this check your vent hood where the dyer vent exhausts out of the house. If it's obstructed you found your problem
Nov 27, 2010 | Bosch Nexxt 500 Dryer
Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Jun 01, 2008 | Candy CDC266 Dryer
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
417 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
