Question about Panasonic KX-TG6500 Cordless Phone
2-line phone Two line phone will not operate with both lines plugged in. Both lines will work independently.
  • 1 more comment
  • leo carlin Jan 30, 2008
    I just had a second line put in my office today. When I plug in both lines to the phone, none of the phones in the house will work--Even the phones that only have the original line shut down. I can plug in each line independently to the phone and all is OK.
    I just had a second line put in my office today. When I plug in both lines to the phone, none of the phones in the house will work--Even the phones that only have the original line shut down. I can plug in each line independently to the phone and all is OK. I have consulted the operating instructions and the troubleshooting section within.
    I found the problem. With two separate lines coming into the phone, one of them had to be a two-wire line and the other a four-wire line. I had two four-wire lines. The circuit was interrupted.
    Genius:
  • 1,226 Answers
You should trace the original line and then connect it using the parallel connection so that there is no interupting in each phone.
If you use the original line w/o connecting the 2nd phone the phone works.
Posted on Jan 30, 2008
    Genius:
  • 1,067 Answers
What about using just spliter then it can grab from both sides of the line proably what u should get
  • nick helpap
    nick helpap Jan 30, 2008
    so one lines comming from home line other office line on line 2 2 seprete inputs but one from home cuts it off how long is the wires from office to that phone might be option in phone menu u may wann se read manel to set it
  • nick helpap
    good to here buddie was gona ask about lies next thx agian
    Genius:
  • 3,422 Answers
try using Easy JAck it will solve ur problem.
Check this out,click here
Goodluck,
Dont forget to rate me as fixya..
Posted on Jan 29, 2008
  • 1 more comment
  • Priya darshan Jan 30, 2008
    Did u try refering to the user manual?
    If no,thn go here enter ur mail id and download one
    Hey check this out too,im sure it will help u to some extent..
    click here
    Hey check this out too,im sure it will solve it
    click here
    Champion:
  • 207 Answers
It will not work unless there's a 3RD party software that can seperate 2 connections. is it connected to the modem?
Can you use the nortel t7316e on a normal land-line..? I've noticed if I plug it in to a land-line that the top left red light flickers on and off, along with the microphone button bottom left and the...
You get around the problem by unpluging the phone and taking it back to wherever you got it, or going out and buying a CICS, MICS, or BCM cabinet to plug the phone into.
A Multi-line digital phone doesn't operate on a POTS telephone line.
Carl
May 28, 2011 | NorStar T7316E Corded Phone
I have a Hp laserjet m1522n and I can not receive a fax
Call your fax number from a cell phone. Listen to the fax noise on the phone and watch the operator panel on the printer. It should show that a fax is coming through.
If it doesn't, call your phone company and have them check the line from their office. If they say that the line is good, try swapping the phone line. Also plug a telephone into the end of the phone line coming from the wall. See if the phone works. If the phone works, you might have a bad fax card in the printer.
Feb 24, 2011 | HP LaserJet M1522n MultiFunction Printer
No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
Mar 20, 2009 | Uniden TRU9466 Cordless Phone
Home phone
unplug phone line from printer, see if phone is operational, try another phone in the wall plug, if not working, go to outside box and plug phone into the test item, if not working call phone company as it wuold appear line dead/cancelled.
Jun 21, 2008 | Office Equipment & Supplies
UPS noise on my land-line phone
Try using a phone surge supressor independently of the UPS - many outlet strips have them as part of the surge suppressor these days.
Jun 13, 2008 | Computers & Internet
Phone connection for Lucent 854
You can get a splitter for it which will then divide that one phone jack into 3 out or 4 out which ever you need. the only problem that you might run into is how close the phones might be to each other. Otherwise there isn't much other ways around it with only one phone jack.
Mar 31, 2008 | Lands Phones
HISSS on line; no dial-tone; no fax in or out
it sounds like you may not have any dial tone. the hiss [white noise] you are hearing is from the dsl modem.try plugging a regular corded phone into the jack to check for dial tone.if there is none,call your phone company.also try plugging the fax machine into another jack where you know there is dial tone.
good luck
wg
Feb 02, 2008 | Brother FAX-2920 Plain Paper Laser
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Programing
Here are some suggestions Volume You may adjust the ringer, speaker, handset and headset volumes independently with the VOLUME ^ and VOLUME v buttons. Your telephone comes with predetermined settings which can be adjusted to individual taste. You will hear an error tone when the maximum or minimum volume level is reached. During volume adjustment, a ?dashed line? icon shows in the display. Adjusting the Ringer Volume Press the VOLUME ^ or v button while in on-hook mode. And/or 1 Selecting a Ringer Tone You may select the ringer tone for each line independently. You may choose to turn the ringer off or select one of the four available ringer tones for each line. 1. Press STORE. The red indicator blinks indicating unit is in Store Mode. 2. Use the number pad to select a ringer tone 0 through 4 (selecting 0 turns the ringer off). 3. Press STORE and then press the desired line button. NOTE: The line indicators continue to flash for incoming calls even with the ringer disabled. You may not select the same ringer tone for both lines. Checking the Ringer Settings Check the setting or each ringer (on, off) by pressing STORE, followed by LINE 1 or LINE 2 button when the phone is on the hook. The ringer setting of the selected line will be shown in the display. If there are any further questions or comments please post here. Please rate this solution through fix-it. Thank you.
Jun 23, 2007 | GE 29485GE2 Three - Line Speakerphone w/...
Panasonic KX-TG6500 Cordless Phone Logo
129 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
