Question about SanDisk Sansa c200 MP3 Player
Need help My sansa c200 broke recently from the dock connector port. the little wires on the inside are bent and broken and it does not connect to my pc.
  • 8,596 Answers
If it is in warranty, call Sansa and get a replacement. If not, get a new player, b/c no one will repair it - it is not cost-effective to repair an mp3 player with damage that extensive.
Posted on Mar 07, 2008
Fiat stilo boot open sensor
You may have broken it or bent or wire connector is off, you will need to locate the latch and may need to remove it and see if the switch is bent or connector is off, sometimes it gets bent or broken for you trying to open the hood (boot) with screwdriver.
Jan 06, 2013 | Cars & Trucks
My Dell Latitude XP laptop got knocked to the floor. It fell on the side where usb port was connected to printer. Usb port pins are now bent and port is unusable. Dell said I have to replace...
No, it's not the only way, if you have an unused PCMCIA port in your notebook. The width of the PCMCIA port is about the height of a credit-card, and the height of that port is about the thickness of a few credit-cards.
Purchase a PCMCIA adapter that has two or three USB ports.
Insert the PCMCIA adapter into the slot,
and connect your USB device to one of the USB ports.
Oct 10, 2010 | Dell Latitude D610 Notebook PC
How do I re-charge the C200 battery?
I have both C240 & C250 players so I shall assume that your C200 uses the same method:
there is the cable included with the C240 player that has a USB connector that goes from the PC or laptop USB port to the player's multi-pin connector. This supplies power to the player to charge the battery. When you plug in the cable to both ports, the player's display will light up and you will see a little "battery" icon symbol in the upper right corner of the display that indicates the charging action and status. It's tiny and hard to see, but the green on the battery icon will get a steady green color when charging is complete.
Also, after-market re-sellers (Dealextreme, et al) have both car outlet and house wall outlet adapters specific for this model, as well as generic models with USB ports. However, I cannot vouch for the safety or quality of these merchants or their products.
Jan 15, 2009 | SanDisk Sansa c200 MP3 Player
Bose docking station chip broke off
I had the same problem that the ipod would onl play when I pulled it forward in the dock. Looking closely, I saw that some of the pins on the left hand side of the connector were bent forward, so I bent them back with a needle:
(ie. pushing the pins to the right, as shown here). This solved the problem for me.
If your connector is too far gone, I suggest looking to:
http://www.chargeconverter.com/shop/connector.htm
for a new connector for £3-4 or
for a whole PCB (Printed Circuit Board) replacement for £10-15.
Hope this helps...
Nov 26, 2008 | Bose SoundDock digital music system...
I don't know how to load music from the internet to my new mp3
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel1.gif Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data1.gif folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 28, 2008 | SanDisk Sansa e200 MP3 Player
Cant load songs
Windows XP SP1
Intel Pentium class PC or higher
CD-ROM drive
TRANSFER MUSIC
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Dock connector port
Try going to repair your iPod at apple.
I don't think they will accept it because it is a old version.
You can try.
Hope this helps!
Nicholas
Jan 27, 2008 | Apple iPod nano
Connection problems Sansa c200
Sandisk provides "how-to" videos for everything Sansa related
You should check out the sansa community forums, they are very helpful
Very helpful Sansa user Forum
Offical Sandisk Sansa user Forum
Oct 28, 2007 | SanDisk Sansa c200 MP3 Player
One earphone works
i had the same exact problem with mine. Reading around it seems to be a common problem with the Sansa line. I opened mine up and found that one of the solder points that holds the ear phone jack to the main board had come loose. I soldered it back and it works like a charm. Pretty easy too. If you have a soldering iron, just open it up and resolder the solder point that has broken off. You can read instructions for disassembly here: http://www.anythingbutipod.com/archives/2006/11/sandisk-sansa-c200-disassembled.php When you have it apart, looking at it from the side, with the jack to the right, the broken point should be the rear (closest to the circuitry) point. You will see a very small, not sure what to call it, chip on the board you have to solder a connection to. here is a diagram: http://i42.photobucket.com/albums/e321/fuzzygoat/sansa-c200-disassembley-8.jpg Hope this helps.
May 10, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
62 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
