Question about Polaroid PDV-0701A Portable DVD Player
No picture on screen
When box is turned on,screen is dark. Put dvd in,still dark, but sound is good when play is pressed. Any ideas, would bad laser cause dark screen
or something else perhaps.Thanks for your help
  • JudeDude92 Feb 20, 2008
    The DVD player, a DAC628 RCA model, plays sound fine when DVD is in the drive, but there is no video on the screen. Completly black, can not fix.
  • abrahamnow Mar 20, 2008
    I also have the same problem. I can sort of see what is going on on the screen but it is really dark. As if the brightness is turned WAY down. (I've turned the brightness up and that does nothing). Anything to keep me from chucking this in the trash?
    Brigadier General:
  • 6,966 Answers
Initially, this would either be a defective LCD panel or its interface. A way to verify is to play the portable DVD using an external video monitor such as your TV. If still gray or blue screen (no video) even in the TV/monitor, then it would be the video interface/circuitry. If the video is displayed, then it would just be the LCD panel display.
If it turns out to be the LCD display, it is very possible that it is a backlighting issue. Most likely, it would be in the inverter and/or CCF (cold cathode florescent) lamps. This is a relatively easy repair by re-soldering. It is perhaps more of a task to open the panel lid/cover of the LCD display.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 30, 2008
Left half screen is dark
Open your left eye ...
OK, just kidding. If your TV or its remote control has a Reset button you can press it twice to reset the TV to original factory conditions (but you lose all customised picture and sound settings). If the TV receives its signal from a cable box or DVR, try connecting a different device such as a DVD or Blu-ray player and play a movie disc. If the problem on your TV screen still exists that suggests the TV needs repair or replacement. If the picture is OK when playing a DVD movie that suggests that your cable box or DVR is faulty and needs replacing (usually free from the cable TV company).
Dec 28, 2015 | Sanyo Televison & Video
Screen does not lighy
If you look very closely, is there an extremely dark picture, or a solid black screen? If it's an extremely dark picture, you just need a new backlight. If it's a black screen, you either have a bad connection (broken, shorted or unplugged cable), or need a new LCD. Let me know, and we'll go from there.
Sep 05, 2007 | Cyberhome CH-LDV 712 Portable DVD Player
No image on LCD Screen
my problem is that the disk almost got stuck in the DVD player, might have been a loose bolt or something. any ideas?
Apr 10, 2009 | Televison & Video
57HX81 Toshiba. picture gets squiggly on dvd input
Perhaps 2 things. Does TV get a picture without DVD connected? If so I would bet you have a faulty connection in your signal board where the in jacks are at the back of the TV . Check to make sure cable from DVD are not bad, I have used cables before and got a false positive. Try turning and spinning the jacks once you have a picture.Make sure your signal board is firmly pressed into its slot on the signal board chassis. Thats it for now. Good luck.
Jan 20, 2009 | Toshiba 57H81 57" Rear Projection...
Unable to get play dvd or get picture on DVD channell on tv
If the player is doing that for all DVDs but playing CDs properly, the player has gone bad due to either the laser and lens being out of whack or the DVD drive just doesn't recognise DVDs anymore and needs repaired or replaced.
Sorry. Best of luck.
Jan 01, 2009 | Philips Televison & Video
GPX PDL705---Picture very dark
Sounds like the back lighting of the LCD screen is faulty. Is it a new unit - take it back. You might try the brightness and contrast controls and turn them up. If that doesn't help it needs to be repaired.
nssms
Sep 09, 2008 | GPX PDL805 Portable DVD Player
Split screen, dark and then light, picture freezes
From what source ? Does it happen when you play a DVD ?
Cable direct? Cable box? Satellite box?..........T.
Dec 14, 2007 | Hitachi 43FDX01B TV
Dark Screen
sounds like a faulty Backlight.. If you just bought this take it back and get it replaced, Check if the Manufacturer's warranty is still valid. if this was bought second hand (out of warranty) I would take it back. as it is unlikely that the prev owner did not know of this issue.
Nov 03, 2007 | Supersonic SC-299TDVD
Tray opens but won't close or closes but doesnt play
deferctive laser lense already. try to replace if more economical than buying new unit
Nov 17, 2006 | Yamaha DVR-S150 DVD Player
Reads CD's but not DVD's
Hi I responded to Parisica's problem, so you have read the "bad news" already. All I can add, is that we see your problem quite often, and without spouting a bunch of tech jargon, lets just say it is easier for the laser to read Cd's than DVD's, so quite often when the laser begins to fail, DVD's will no longer play, but Cd's are fine. I'm not an expert on your model, but Parisica mentions a menu setting that turns DVD video on & off, which may be worth checking, and also cleaning may help, as a dirty laser lense can give the same symptoms as a weak laser. I don't want to get your hopes up, 2-3 years of service can certainly be long enough for laser problems, depending on how much you used it. Good Luck!
Aug 15, 2006 | Kenwood DV-6050 Multi-disc DVD Player
Polaroid PDV-0701A Portable DVD Player Logo
185 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
