Question about Sony Handycam DCR-TRV280 Digital Camcorder
Some tapes won't play back
For some reason, I can play back some tapes and others won't allow me to. I get the blue screen with no counter. It will rewind, ff etc. I am able to record and playback. Is this due to the tapes being over 3-4 years old and need cleaning? How can I clean them?
  • biggie8388 Jan 29, 2008
    Thanks Early!
  • 871 Answers
Hey there.
yes, this is due to different span of time of the tapes.. tapes longer than 4 years start to grow molds, thus, all the tapes needs regular cleaning. if its not clean, then it wont br readable.
there are cleaners out there and you can purchase one from any electrical stores.
Posted on Jan 29, 2008
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
I have a VHS tape that has an hour worth of recorded material on it, but when I play it, it plays the first 11 minutes, then it goes to static and the counter stops counting. I can fast forward but when I...
You may think the tape has an hour of material on it, but the machine thinks otherwise. Either it didn't actually get recorded past the 11 minute point, or something erased the tape past that point. There's nothing to play after that time, so you're seeing the snowy screen. On most VCRs, the tape counter only works when a valid video signal is detected, which is why it's not advancing as the tape plays. There's nothing you can do to recover whatever was on the tape, so I hope it wasn't anything important.
Aug 11, 2011 | TDK E-HG 120 VHS Tape
Hi, I have Sony TRV238E HI8 Camera recorder. When I in play/edit mode, only have blue screen on the LCD with counter to and other parameters . In this mode if I move the tape Rew. or FF I have regular...
Based on the information you've provided, it seems that the issue is with the dirt in the Video Head of the Camcorder. You can try using new Hi8 tapes for recording the videos to check if they are playing back normally. If the audio is working normally in the Camcorder, then the issue is with the dirt on the video head. If the issue persists with all the tapes, then the video head can be cleaned using a dry Video Head Cleaner Cassette. You can purchase the cassette from the Sony Authorized dealers or from the local electronics store. Please make sure that the cleaning cassette is compatible with the Camcorder.
This should resolve the issue.
Thanks for using FixYa.
Jan 17, 2011 | Cameras
Blue screen on lcd screen
The playback head is probably dirty and cannot show the picture - the screen is blue. Run a blank tape in the tape drive and execute a record all the way through the tape. Then play back a pre-recorded tape to verify it plays back ok.
Nov 11, 2010 | Sony DCR-HC30E MiniDV Camcorder
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Tapes will not play
Video head is dirty / clogged. Use good quality Mini DV Head Cleaning cassette.
Oct 01, 2008 | Sony DCR-HC32E DV Digital Camcorder
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Vcr tape problem
It sounds like the tracking information is being lost for brief periods of time. Tracking is recorded at the lower edge of the tape, and if the tape is wrinkled or otherwise damaged in this area, playback will go out to lunch. A visual check of the tape would be in order. Have the heads been cleaned in these machines? This would be another area to check.... Also, there could be small differences in the tape path alignments, perhaps the control/audio head alignment is slightly different between the 2 machines.
Apr 28, 2007 | Panasonic AG-1980 S-VHS VCR
Sony Handycam DCR-TRV280 Digital Camcorder Logo
267 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
