Question about Gevalia CM-500 12 Cup Coffee Maker
Coffee temperature How do I set the coffee temperature to stay hot once the coffee is brewed? I would appreciate it if you could also e-mail me the answer to [email protected] Thank you, Raquel
  • Anonymous Feb 27, 2008
    wont brew
  • 2,042 Answers
What kind of machine????????????
Posted on Jan 29, 2008
6ya staff
SOURCE:
Temperature
The temperature was set for optimum functionality at the factory and cannot be adjusted manually. It is important to have very hot water to get a quality brew; thus if the temperature is too low call 1-866-901-2739 for service.
Feb 07, 2014 | Keurig B31
My keurig special edition brews pretty hot, I do add creamer and sugar, but will only stay hot for no more than 8 to 10 minutes, is this normal?
yeah, that is normal. some keurig models allow you to adjust the brew temperature. If yours does, I'd crank it up a few notches. If yours does not have that feature, you may need to use the old microwave trick.
Dec 31, 2011 | Keurig Special Edition B60 Coffee Maker
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
I have a keurig b 60 brewer and i don't feel the water is hot enough. i just got it last night 12/23/10 can u suggest anything?
Sorry to read about your problem, I hope this helps you out.
ProgrammingBrewTemperature (187°-192oF)
The Brewer brews at a preset temperature of 192°. You can adjust this temperature down by 5 degrees if you prefer a cooler cup of coffee, tea or hot cocoa. Simply follow the instructions below.
1. Press the Menu Button on the LCD Control Center five times to program the Brew Temperature feature.
2. The LCD Control Center will now display the programming options with a small arrow next to "SET BREW TEMP" (fig. 15). Also, the temperature 192° (initial setting) will be displayed at the bottom of the LCD Control Center to indicate the current temperature setting.
3. A minus sign will appear over the Small Cup Button and/or a plus sign over the Large Mug Button. Use these buttons to raise or lower the temperature one degree at a time.
4. Once you have reached your desired brew temperature, press the Menu Button once to exit the programming mode. "BREW TEMP SET" will be displayed in the LCD Control Center if you have changed it from 192°.
5. To change the brew temperature again, repeat steps 1 through 3 to change the temperature up or down, remembering that the temperature can only be between 187° and 192°.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Keurig B60 Coffee Maker
Coffee brewing comes out in a fast steady stream when brewing, coffee doesn't brew properly and comes out weak. taste like unbrewed.
If it comes out in a steady "stream" it sounds like the sprayhead is missing. The sprayhead disperses the water out and evenly over the grounds.
If the sprayhead IS in place then it could be a temperature problem. If the temperature is not hot enough the coffee will not brew correctly.
Sep 06, 2010 | Bunn Coffee Makers & Espresso Machines
We have a CBC-1600 10 cup coffeemaker. after brewing the coffeemaker beeps and turns off. The hot plate part of the coffeemaker will not stay on for longer than 5 minutes.
The CBC-1600 is designed differently than you might expect. The stainless steel, insulated carafe is designed to keep the coffee hot instead of a hot plate keeping a glass carafe hot. Some people like that style better (including me). Some people - like my dad - don't think it keeps the coffee hot enough.
Your coffee maker is working exactly as designed. The carafe itself is designed to keep the coffee at the same temperature as it was brewed.
Dec 24, 2009 | Cuisinart Coffee Makers & Espresso...
Cuisinart DCC-1200 brewing temperature
Hello ditommm,
Not to worry, I think I can help. On the face of your DCC-1200, there are two black switches. The right one adjusts the carafe temperature. With the white line to the left you get a lower carafe temperature. With it all the way to the right you get the highest (hottest) temp. Of course, in the middle, you get a medium temp. I use mine with the lowest temp so that I don't end of scalding my lips and tongue when I drink my coffee. Use this bit of info to adjust your carafe temps. If you are looking to cause the actual brewing temp I don't know of a way to do that. Coffee needs to be brewed at the set temp in order to break down the elements of the ground coffee. I hope this is what you were looking for in an answer and that it is helpful. If it is, please consider leaving positve feedback for me. I will certainly appreciate it. Good luck! Regards, NormanZ
Jul 07, 2009 | Cuisinart DCC-1200 Coffee Maker
I have lost the manual for the Cuisinart Brew Central, model CBC-00, coffee maker. My question is this: What the "carafe temp" knob does with L and H selections? I assume it is to select the carafe...
Hello pdmkali,
Your assumption about the carafe temps is correct. The middle position gives you a medium temp, of course. I use it on low so that I don't burn my lips and tongue when I drink my coffee. Thank you for the opportunity to answer your question. If it is helpful, please leave positive feedback for me. It is appreciated. Regards, NormanZ :o)
Jun 28, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee Not Hot Enough
probably need to descale the machine scale stay on the heater and doesnt heat as much use descaler not vinegar thanks pierre
Jan 11, 2009 | Krups Small Appliances Espresso Machine
Coffe does not stay hot in carafe
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red.
Mine also doesn't seem to keep hot also.
Mar 19, 2008 | Krups ProAroma 453-71 Coffee Maker
Open Questions:
See all Gevalia CM-500 12 Cup Coffee Maker Questions
Coffee Makers & Espresso Machines Logo
160 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
Vitally Alcher
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
