Question about Black & Decker BL5900 ProBlend Work Top Blender
Blender dead I disassembled the blender and found a board with a controller ic em18156 ,a triac , a 5v regulator and two small semiconductors s8050 i dont know what they are,transistor or scr if you let me know i will appreciatte. So what other cause are the reason the blender is complety dead. rgds marco
Well all electronics was fine, the problem was the thermal fuse with the field winding was open I replaced it and the problem was solved.
rgds
mloo55
Posted on Feb 09, 2008
Burnt smell on oster blender
If you have eelctric knowledge, disassemble the case and look for some corroded contact or cable.
You can follow some of these youtube tutorials or look for additional info by doing a Google search using terms
Youtube disassemble blender
iFixit Blendtec Total Blender Disassembly
How to open and repair Braun Hand Blender Part1
KitchenAid Blender Coupler Repair KSB5 Model
OSTER Blender Repair How to fix an broken driver
If you are not familiar with disassembling a blender but you feel you have the knowledge to do it, take a photo of each step so when you have repaired the problem, you should have no problem to reassemble it again
Sep 04, 2013 | Blenders
Blender now only has one speed and it's overspeed. Is there an overspeed govenor that causes the blender to automatically shut off? It will overspeed about 3 seconds before it stops working and all the...
there is a voltage regulator inside the circuit board , this might have got wet some how . this circuit controls 1-10 speed from a touch of a button . will have to disassemble unit , Auth personal should check this , unless you know electronics
Mar 19, 2010 | KitchenAid KSB3 Classic Work Top Blender
Disassemble
we found the solution to the problem on your website.
Thank's for the tip.
Feb 15, 2010 | Robot Coupe MP450 Handheld Blender
My blender stopped smells like plastic
your triac module has shorted on the circuit board
Sep 23, 2009 | Oster 4093-8 Osterizer Classic Blender...
KitchenAid Blender KSB5WH3 flashing lights how to get to the fuse
i found broken solder connections on triac on circuit board. it's the part with the cooling fingers that surround it. pencil soldered the cracked connections; now works fine.
Jun 19, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Power flashes but doesnt start
Yes, I know what it is. On the base of the blender jar (the plastic base) there are some "fingers" that must contact the base to allow operation to take place. Turn it upside down and look at the little plastic "fingers" around the outside periphery of the plastic base.
These fingers tend to break over time... mine only has two left right now, and it only works in one particular position as a result.
Rotate the blender jar one spot at a time until you are able to operate it "normally". I use it for margaritas, and it won't allow me to push the button for Frozen Drink unless the jar is in the right position.
I am going to try and find a replacement base (or entire blender jar) somewhere... or else I will finally have to retire my favorite blender of all time!
Dec 20, 2008 | Oster 6700 Work Top Blender
Cusinert blender
I had the same problem and I manaed to fix my Cuisinart SmartPower Duet blender. There are two thermal fuses, one tape attached to each stator winding. Both of mine were blown.
In addition, when the fuses blew, it must have spiked the triac. I had to replace mine. It's the black 3-legged transistor looking device with a small metal heatsink attached to it. This gizmo directly throttles the power to the motor under control of the microprocessor. There are some guides on the internet on how to test it.
Also, the clutch was very hard to remove and needs to be removed to more easily replace the thermal fuses. I clamped down the end of the motor shaft to a bench vise real hard and then I used a 7/8-inch open-end wrench to wedge into the clutch prongs which made it much easier to apply torque. Remember that its screw threads are reversed from normal screws so that it does not unscrew during operation. You have to turn it counter-clockwise to unthread it.
Hope that helps!
-Vince
Sep 13, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Kitchen Aid blender
to see if its the Triac or just the off button perform this: connect the blender,while pressing the off button press the on button; if the blender stays on and you dont hear the relay function (Light ticky sound) maybe the off button get a broken solder point. But if the relay is functioning and there is no way to change the speed the problen is the TRIAC. This is a small piece on PCB with a heat sink
Aug 30, 2008 | KitchenAid KSB3 Classic Work Top Blender
Blender blinks
need to resolder the triac located on the Printed circuit board this part is on an aluminum heat sink, and the third leg is most of the times the one with a broken or poor soldering joint due to the vibration of blender
Dec 27, 2007 | KitchenAid KSB5 Professional Stainless...
Black & Decker BL5900 ProBlend Work Top Blender Logo
327 people viewed this question
Top Black & Decker Blenders Experts
Marvin
Marvin
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
