Question about Summit Commercial 7.50 cu. ft. / 212 liter Chest Freezer FCL88
Bar Chest Freezer Large
We have a chest freezer for frosted mugs and martini glasses. It stopped working so I unplugged it and took the back panel off. The main red power wire running into the condenser was disconnected and looked like it was melted a little. I figured it got wet and arched itself out. I respliced the wire and plugged the freezer back in. It was running the condenser kicked on and the fan was spinning. I let it sit for 3 hours and when I came back still not cold. Nothing just running and the inside was about room temp. I tryed to adjust the temp to a higher temp but still nothing. I was wondering if there is an easy way to fix the problem or somewhere I can go to get a manual to should me how to trouble shoot the problem myself. We have had it worked on three times so everything inside is new. The arch would have caused the p[ower failure to the condenser stopping the freezing but what could be wrong now.
    Sergeant:
  • 288 Answers
I would think that the reason the red power wire melted, was because of high amperage, not getting wet. After you replaced it the condenser fan came on, but did the compressor? It may have went out before and that's what caused the bad wire. If you have a volt/ohm meter I can help you check it out.
Posted on Feb 16, 2008
How tofind out if your chest freezer is stuck onn defrost mode
If its in defrost mode it will get warm and the frost will melt. People usually just unplug them. Tge compressor usually has a switch or temp knob. It may be in back by the compressor underneaith. There would be an indicator as to the temp.setting on it. It may not have one at all and may have another issue.
Jun 23, 2014 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Why is there a lot of frost in my woods v15nab freezer?
On a chest freezer, frost always accumulates around the top perimeter first because the warmer moist air comes in contact with that area first once the door is opened. More frequent defrosting may be the answer.
Jun 08, 2014 | GE Freezer  14.8 Cu. Ft. Manual...
Frost building up at the coil. i think the defroster does not work
Chest freezers are manual defrost. Which mean yall unplug it to defrost it.
May 12, 2011 | Woods Chest Freezer C1501W3
Freezer just stopped working
Is this a frost free freezer? If it is, and the compressor and refrigerant is good, the problem probally lies with the defrost timer. What the defrost timer does, at regular intervals, typically every 12 hours, shuts down the compressor and powers up a defrost coil to melt any frost that has built up on the cooling coils inside the freezer. It probally the small square box that you mentioned. Some have a hole where you can turn the cam to the timer and that should switch the power from the defrost coil to the compressor.
Hope this helps.
Jun 27, 2010 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Just got a used 5.0 frigidaire chest freezer and noticed that it is starting to frost at the top but water is starting to pool at the bottom. any help would be appreciated
Good day,
The interior walls should frost evenly. If you only get a partial frosting pattern then either you have a refrigerant leak or a restriction in the refrigerant lines.
Either problem would be considered a terminal failure in a chest freezer.
Mar 29, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
How do u defrost a ge chest freezer
Don't hit or punch the freezer walls ,just unplugged and let the frost melts and this water will go through the drain down to an evaporative pan.Make sure the drain is not clogh if it is clogh put hot water into it or blow it with air pressure.
Aug 13, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
Frost in Chest freezer
Not much you can do except ensure you have a tight seal and not to open it more than you have to.
Oct 23, 2008 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Excess frost not keeping food frozen
you have a refrigeration issue. let me guess. is the frost real thick around a small area not the entire lining? if so you have a restriction or leak. cheaper to replace by the way
Apr 14, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Summit Commercial 7.50 cu. ft. / 212 liter Chest Freezer FCL88 Logo
107 people viewed this question
Top Summit Commercial Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Summit Commercial Freezer Expert? Answer questions, earn points and help others
