Question about Kenmore 74962 Gas Dryer
Amana Gas Dryer
Will not heat up. Filter is clean. Swept under it....
Amana enery saver desinger series model lgm 439w will not start, it will click and then I smell burning wire.
Posted on Feb 17, 2008
Amana ned7200tw10 intermittent heating problem. New heating coil installed but dryer does not always run through heating cycle. Codes that come up are 2 and 10 when in diagnouses mode.
Sensors may be coated with waterproof wax from dryer sheets. Wash them with windex. The dryer not sensing moister it THINKS them clothes it dry. Cleaning the sensors works. Try it. The sensors will be behind the filter wall just below the filter on most sensor type dryers.
Feb 14, 2013 | Amana NED7200TW Electric Dryer
Amana gas dryer LG8319W/L2
try getting a lint trap brush its long so u can get all the way down in the trap try cleaning that first that is usally the problem
Nov 17, 2011 | Amana Dryers
Amana dryer will not heat. Exhaust duct is clean. Suggestions?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.
Oct 11, 2010 | Amana LEA11 Dryer
I have an Amana dryer Mod. ALG649RAW. Turn dryer on ignites than flames, but after a few minutes goes out, it will again ignite, but won't flame. Is it overheating? The dryer is vented underground about...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 28, 2010 | Amana Dryers
My dryer isn't heating. The vent is clear and the lint filter.
heatman101
Aug 07, 2010 | Amana DLG330RAW Gas Dryer
Amana gas dryer mod #NGD5240TQ0 intermitten heat
i went to a local appliance store asked them for assistance. they were more than helpful and sold me the parts i needed. fixed the problem for under $30.00. i also didnt have to pay for their ADVICE !!!
Aug 22, 2009 | Amana Dryers
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Dec 24, 2008 | Amana Dryers
Amana Dryer LG8409W2 - The dryer heats for a few seconds then runs cold. The dryer has been cleaned as well as the vent and still no heat.
karenl46 -- Flame sensor has to "see" proper flame in order for gas burner to stay on. Safety solenoid engages (shuts off gas) when flame light not detected. Check window on sensor (1:30 CW position) on burner tube. If you still have problem after cleaning it, then refer to URL below. -- SWT
http://forum.doityourself.com/kitchen-laundry-home-gas-appliances/350993-another-gas-dryer-no-heat-failure-rates.html
Aug 18, 2008 | Amana Dryers
Kenmore 74962 Gas Dryer Logo
65 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
