Question about Mitsubishi WT-42311 42" Rear Projection Television
Blue and yellow shadows on Mitsubishi TV rear projection WT-42311
I have a problem with blue and yellow shadows on the left half of the screen. I have looked at the convergence screen and the left half of the grid I can see blue lines extremely off center and angled. Right side is fine.
  • 790 Answers
Resolder the convergence correction IC! That is STK IC attach in aluminum heatsink!
Posted on May 07, 2008
What are ICs? and where are they located
Posted on Apr 09, 2008
    Scholar:
  • 90 Answers
Resolder and/or replace the conv ICs.
Posted on Feb 07, 2008
Mitsubishi ws-48311 blue and yellow shadows
I would suggest you go into the menu and select convergence and then advanced convergence (set will display on screen instructions) and call up the grid of lines by doing that---the grid of lines you see should all be yellow---if you see red or blue lines out of position try with the Mitsubishi remote to adjust them.
If they will not adjust the set needs the convergence circuit repaired.
For many if this is the issue it can be a do it yourself repair--I have complete instructions for this repair in this set---start to finish.
Look first to see if this is your problem.
SD TECH
Apr 22, 2012 | Mitsubishi WT-42311 42" Rear Projection...
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Our hitachi has horizontal lines across the screen first it was just a small area now it half of the screen what could be causing this?
I have a suggestion that will tell you and me exactly what your problem is--Does set have small button on front that says MAGIC FOCUS? If it does press it and after it starts press it again--it will stop the magic focus and bring up the convergence grid on the screen----you will see a grid of lines and just need to look at them----if red or blue is out of place you have a convergence problem--very common on this kind of set.
If set does not have MAGIC FOCUS BUTTON (IT IS ON THE RIGHT OF THE KEYBOARD AND MAY BE RECESSED) You can remove the front speaker grill and the inspection plate behind it----there is a tiny small push button switch on the left front of the circuit boards--it will have blue button--us something not metal (I use a eraser end of a pencil) this will engage the set into the same convergence mode.
You just need to see what the grid looks like--if it is skewed etc--YOU KNOW YOU HAVE A CONVERGENCE PROBLEM.
If it is a convergence problem I CAN TELL YOU WHAT IS INVOLVED TO REPAIR THE SET---it will depend if you can do it yourself or need to have someone do it for you--most of this repair is just getting at a few parts and being able to do good soldering etc.
Try to check to see if you actually have a Convergence trouble or something else--if the lines on the grid are not white--red or blue bowed or out of place anywhere--it is convergence problem.
Seeing is believing and if you see the grid looks bad.
let me know--I am here to help people---I HAVE FIXED HUNDREDS OF HITACHI SETS WITH ALL KINDS OF TROUBLES--CONVERGENCE IS THE MOST COMMON PROBLEM--BY THE WAY: CONFIRM THAT ACTUAL MODEL NUMBER IS 51F500.
regards, SD TECH
Oct 15, 2009 | Hitachi 51F500 51" Rear Projection...
I have a Panasonic PT-53WX54J that will not Converge
you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
Aug 23, 2009 | Panasonic Televison & Video
Have colored shadows around everything on my Mitsubishi HDTV 1080
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Hitachi 61udx10b picture problem
Replace both of your STKs these are your convergence ICs STK392-110- use STK392-180s .
Dec 14, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Can't adjust blue lines on grid for convergance
I would take a look at the entire circuit board the STK chips are sitting on... I have the same problem with a sony KP-57wv700 and it turned out to be the high voltage controller for the crts got fried... part # BA9759F and it can not be replaced as the entire circuitry around it got toasted also... I just ordered entire circuit board. mine was the D board in this case...
BTW, did you check or replace the pico fuses? 3 orange ones on each STK circuitry. Check their resistance with an ohm gage should show continuity. My case they were 3.15 A each...
Jan 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Not sure, but looks like blue and red shadows around words on the screen
Al, bring up your convergence grid (look in menu for it) and I think you`ll find that the set is out of convergence, if you can adjust the red up & down and the blue up & down your ok, if they won`t move in one or both directions the convergence IC`s will have to be changed out, hope this helps, BMW Rider
Dec 12, 2007 | Zenith D61W25 61" Rear Projection...
Yellow and Blue shadow on left side of screen
Blue convergence off = needs convergence IC's replaced =
Would you like step - by - step how to ??????
Nov 07, 2007 | Toshiba 51H84 51" Rear Projection...
Blue wave shadowing
The convergence Ics need replaced. In Hitachi, resistors and sometimes a coil needs replaced as well. The convergence/deflection PCB is available, but, the cost of that board is higher than having a servicer come to your home and repair the unit to component level. If you are not familar with this circuit, then call a servicer. Have them replace both ICs not just one. Make sure they are repairing to component level and not replacing the board. Hope this helps.
Feb 08, 2007 | Hitachi 43FDX01B TV
Mitsubishi WT-42311 42" Rear Projection Television Logo
260 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
