Question about iLO (2 GB) MP3 Player
New battery no power
My mp3 player has a new battery in it but it won't turn on even when i hook it to my pc help me please im about to smash it!
I am having the same problem. Just bought it a few days ago and it won't work anymore. I used it early this morning while running and got home and powered off - and then when i got to work - it wouldn't power on. thought maybe the battery was dead so i bought a new pack. put it in and still no luck!
If you find help let me know.
I have been reviewing a few reviews and so far it sounds like the ilo sucks!
Posted on Jan 31, 2008
6ya staff
SOURCE:
I have a sumvision cyclone voyager 7 It wouldn't turn off and after battery died it won't turn on even when plugged in Any suggestions? Thx Dave
Sounds like you may have a dodgy power button, you have a 1 year warranty I would call or e-mail sum vision, I have one of these systems and there not bad I've not had a power button problem though. Hope this helps!
Jan 02, 2013 | Audio Players & Recorders
My ipod 30gb needs to connect to its charger before it power on, and sometimes when i disconnect it from its charger sometimes my ipod will also shutdown, My next problem is that, when my ipod 30gb...
The Batteries in these units like all rechargeable batteries only have a certain number of times they can be charged and discharged before begining to fail. Your only option is to replace the battery with a new one. They are cheap to purchase off eBay and YouTube has Videos detailing how to change them.
May 06, 2011 | Apple iPod MA446LL/A MP3 Player
Model#1825 it wont charge or turn on
Hello :
It seems that the battery is dead [ can't be recharged anymore ] . You need new battery . If you replaced the battery with new one and the device still can't be recharged , then I recommend you to take your player to the service .
You may also check the power transformer or power cord .
good luck .
please rate
Mar 30, 2010 | Toymax Impecca MP-1825 MP3 Player
My 120G zune wont charge....it wont even turn on. ive left it hooked up to my computer and wall-charger for days. and the reset methods dont work. help!!
Hello :
It seems that the battery is dead [ can't be recharged anymore ] . You need new battery . If you replaced the battery with new one and the device still can't recharged , then I recommend you to take your player to the service .
good luck .
please rate !
Mar 30, 2010 | Microsoft Zune JS8-00001 Digital Media...
My mp3 player doesn't turn on even if I charge it. Do you think I need a new battery?
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, to switch the player to MSC mode
1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Skip this step if you think it is charged. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa m230 MP3 Player
My sandisk sansa clip 1gb wont turn on
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
Turning on my mp3
has your MP3 player smashed on something or banged on anywhere?... Coze it may be damaged.
If that's not the case you should check it with new batteries coz old batteries mite be empty
Lastly if none of the others are in place you may have a real problem with your MP3 player and you should go to some technical repair shop to fix.
Nov 28, 2008 | Philips GOGEAR SA6045 MP3 Player
Turn on
i bought eight new batteries had it for a year and now its dead i tryed all the batteries even try hooking it up to my pc but it wont turn on how do i fix this problem?
Feb 05, 2008 | Nextar MA933A MP3 Player
Brand new sansa view not working
hold the play/pause button and the power button until it turns off then turn it back on and it should be good. hope i helped!
Dec 25, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
Wont turn on!! :(
Maybe you should charge it.
Jul 08, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
42 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
