Question about Sony KP-53HS10 TV
Sony kp-53s10 picture bowed on all 4 sides, already replaced convergence ic's
  • 44 Answers
Hi: Check the horizontal output stage. Many Sony chassis have a control scr device on the emitter of the h.o.t. or the flyback may be bad. Good luck.
Posted on Mar 08, 2008
On my Sony KP-65WS510 The colors are misaligned in the picture and the picture is bowed. Any ideas? Thanks!
This problem appears due to convergence output ICs failure located on D board in tv. There are two big black ICs that need to be replaced, soldering work is required.
Let me know are you handy with electronics stuff repair and can replace parts in circuit board to provide you more technical info OR local tv repairman will do this job for you.
Thanks.
Nov 23, 2010 | Sony KP-65WS510 65" Rear Projection...
The top of the picture is bowing down, and the bottom of the picture is bowing up, and throwing the convergence out. What is causing this?
The 2 STK convergence ICS and some or all it resistors are the cause and is dead.The tv convergence board require these parts to be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 13, 2010 | Sony KP-61HS30 TV
KP-51WS510 convergence problem. Replaced IC's and pico fuse
Nothing else to look for but to Replace the Convergence Ic's
Nov 06, 2009 | Sony KP-51WS510 51" Rear Projection...
Picture bowed and colors don't line up on my Sony KP-51WS500 Sony KP-51WS500 its bowed and words show up different colors like in 3s.
This is a convergence problem that can be as simple as poor solder connections on the convergence ICs or defecive ICs. If you can solder you can repair this yourself, Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
May 13, 2009 | Sony Televison & Video
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Massive Convergence problems even after replacing IC's.
See a pico fuse HERE and find PS8001 to PS8006 on D board of TV
Mar 18, 2009 | Sony KP-65WS500 65" Rear Projection...
I have a convergence problem. My Sony KP-65WS510 has a picture that looks like 3-D and bows at the bottom and top of the screen. I already replaced both the IC's STK 392-560 (2 qty.) and check all six 3.5a...
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Dec 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Bows on the sides and top of the t.v. screen. The model is KP-57HW40
Have your convergence amps replaced ....by tech and all will be good.
May 29, 2008 | Sony KP-57HW40 57" Rear Projection...
Help
You need to have the convergence IC's replaced. A repair like this should run you about 300 bucks or so. In most places.
Apr 27, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-53HS10 TV Logo
113 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
