Question about Kenwood KVT-617DVD Car DVD Player
KVT 617 CD/DVD "reads" but only audio from tuner
I have the head unit hooked up like it is supposed to including the green wire to the ground but dvds do not play. CDs also do not play, they "read" and by that I mean that the time ticks by on the counter displayed but there is no audio coming from it at all, only on tuner. Does anyone know why this would happen? Could I have gotten a bad head unit?
  • elisabeth227 Feb 18, 2008
    I have the same issue. Ipod and CDs don't play, but everything is hooked up correctly. Havent' tried DVDs yet, but I suspect they don't play as well. Tuner works fine, so we know the speakers are connected correctly. Could I also have a bad unit? I tried the reset button, and we made sure the ground wires are connected right and working. Anyone have any help for this?
  • Anonymous Mar 03, 2009
    codigo
Ok, so I called Crutchfield, where I had purchased the unit, and the guy there said this is a common thing. Believe it or not, it IS the wiring. The guy said the blue wire on the harness needs to be connected to the blue/white wire on the Kenwood unit. Which is weird, since it's usually color-coded. He said the blue wire is a 12-volt amp wire, which works with the tuner, but when you take it off tuner, it kills the 12 volts and so you get no sound.
I haven't fixed it yet to be sure it works, but I thought I'd post this anyway, in case someone else is waiting on this. I'll post again if it doesn't work. :0)
Posted on Feb 18, 2008
NO, its not the wiring. I have the same unit and punched everything in my car and finally figured it out. All I heard was the tuner but no dvd or cd. But then I got it...
1. Go to your tuner
2. Top right hand corner press the ( TI ) button
3. Go back to DVD
4. Works.
Posted on Jul 11, 2008
I have the same unit and mine works fine
Posted on Mar 04, 2008
Worked?????? i having the same problem in my kvt-717
Posted on Mar 02, 2008
Tried this Blue/ blue-white wire switch. Worked perfectly. Thanks to elisabeth227 for the find.
Posted on Dec 21, 2009
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
Hideaway brain unit on my kenwood KVT-617 doesn't work
My KVT-617 display unit was stolen out of my dash, but they neglected to snag the items under the rear seat: the "brain" hideaway unit, the HD radio receiver, the 10 disc CD changer, the navigation unit, and the powered subwoofer.
Everything was replaced via the insurance except the sub because the new system was not compatible with the old components. Make me an offer on the items you want!
timsterp99999@att.net
May 29, 2009 | Kenwood KVT-617DVD Car DVD Player
Need a kenwood kvt-617 brain.
Hi someone stole the head unit out of my car but left behind the brain and wiring.
Apr 17, 2009 | Kenwood KVT-617DVD Car DVD Player
I can not watch the videos and movies in my Kenwood KVT 617 DVD
hi there
on the back of this unit is a green brake wire you need to buy a 3 pined toggle switch ...........you need to take a small but mid size length speaker wire and attach to 12v (red wire) going into back of kenwood unit add another speaker wire to the ground wire (black wire) of kenwood unit... now on the 3 pined toggle switch add the power speaker wire to the toggle switch add the ground speaker wire to the toggle switch once this is done add the green wire to the last toggle switch pin........put the kenwood unit back in dash.......now turn the car and toggle switch on...........put in a DVD and if screen shows DVD all is done...... but if the screen does not show the DVD......just switch the green wire with the black wire on the toggle switch and now it should work
hope this helps
Mar 02, 2009 | Kenwood KVT-617DVD Car DVD Player
Video
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 20, 2008 | Kenwood KVT-617DVD Car DVD Player
Kvt-617 dvd receiver hideaway unit
go to e bay n look 4 someone selling a brain/ hide away unit for cheap..????to use with ya dvd unit.
Apr 20, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-617DVD
hi kenwood go's off when i put it on to dvd
Jan 16, 2008 | Kenwood KVT-617DVD Car DVD Player
Kvt-617 bypass
u can wire the safety wire to a ground or to a switch that grounds the wire and that will bypass it.
Dec 27, 2007 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt 911 dvd head unit
I have a question. Everything is working perfectly except for there is no picture on the TV nor DVD. It was working fine until the other day when I messed around with some wires seeing if any of them were loose. Any suggestions?
Dec 09, 2007 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-617DVD Car DVD Player Logo
356 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
