Question about Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
LOUD WHRRR NOISE AND AT TIMES A HIGH SCREECH
I bought this dishwasher a little over a year ago and all of a sudden it started making these loud noises. This is now the third washing in the row that has been noisy. At times there is a high screech and a constant loud motor sound. Can you tell me what might be wrong?
  • kc_person Jan 30, 2008
    I have the exact same problem with a Viking VDU141, but it is intermittent and it WON'T do it when the repair guy is here. I am beginning to suspect that there may be a very slow leak, so when it is running regularly, water is building up underneath and some flood protection pump (I have read similar things about flood protection elsewhere here) is kicking in, but then I don't use it, and by the time the guy comes - it is dryer and doesn't make the noise for him. I have to call tomorrow and see if that rings any bells with them.
  • juehastings Nov 30, 2008
    I also have had my dishwasher a year and it started making loud noices and is loud while running. It does not clean dishes either. The detergent door doesn't open either.
6ya staff
SOURCE:
Anonymous
SOURCE: kenmore elite dishwasher making loud buzzing sound when washing
I had the same problem with by Kemore Ultrawash after two years. The motor bearing went bad because the seal went out and dish water got to the bearing. If you are handy, this motor comes out after taking the dishwasher out. I was surprised how easily the motor came apart from the dishwasher, a good design. The motor has three screws that holds it together, I took them out and took the motor apart.
I took the old beaing off the shaft with a grinder, careful not to groove the motor shaft. I did, but just put some high temp silicone caulk in the groove before I put the new bearing on the shaft. I bought a new bearing on the internet, it is a 22mm x 8mm x 7mm. I bought one that went in a small engine, a quality one. I placed it on the shaft, put the motor back together and put the dishwasher back together. It has run quiet and great for many weeks now. I expect the dishwasher may last many years now, because the bearing I took out was a cheap aftermarket one, and the new one is vastly superior in quality.
Good luck and fire away with any questions. I love this dishwasher and am glad I could fix it for 19$ and some of my time.
Posted on Nov 08, 2008
Anonymous
  • 9 Answers
SOURCE: Kenmore Elite ultra wash dishwasher
When it is off, reach down around the base of the spray assy and run your fingers around the entire circular base where junk can get caught. I've found broken glass and plastic utensils. Why do some of us wash disposable utensils? Huh? You may find something like a piece of plastic, glass, or the like that is making the noise. Be careful not to cut yourself.
If this buzzying sound is not coming from the tub, and is actually below the tub and in front right side, it is most likely the electrical relay switch ( which can make that sound when it is straining or failing).
Posted on Nov 20, 2008
Anonymous
SOURCE: Loud Humming noise every time we run the dishwasher
Hi, I had this exact same problem. In my situation it turned out to be the pump that pumps out all of the used water. It was rubbing up against the floor so that every time it turned on it made a loud vibrating sound. I just reached under the washer and put a piece of rubber between it and the floor and it solved the problem.
good luck!
I saw this post because I am considering buying the same model you have. Other than the noise problem you have, what do you think of it?
Posted on Apr 06, 2009
Anonymous
  • 572 Answers
SOURCE: maytag dishwasher starts to fill with water and as
you need to get inside to the chopper and see if its stripped. usually parts strip there
Posted on Feb 11, 2010
JEFF SIEGEL
  • 311 Answers
SOURCE: high pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Posted on Jun 05, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
FGHD2433KB1 noise
Sometimes a little piece of debris such as a toothpick, chicken bone, etc. can get past the screen and make it into the pump. The wash arm pulls right off and the part holding the screen can be remove with a twist. remove the screen and then you will see the impellar in the pump whee the debris is at. Hope this helps.
Nov 05, 2017 | Frigidaire Dishwashers
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Fan motor has loud screech.
Check for oil ports on motor. Usually red or yelloe plug in caps. No more than 20 drops of oil. I usually use sewing machine oil.
Apr 26, 2009 | Heating & Cooling
Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
It seems serious enough
you must first determine where the noise is coming from it could be simple as being unalanced
Oct 20, 2007 | Samsung RB2155 Bottom Freezer Refrigerator
Open Questions:
See all Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
136 people viewed this question
Top Jenn-Air Dishwashers Experts
Marvin
Marvin
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
