My GE Washing Machine Steel Drum is tilted and it makes a lot of noise when it is washing. It caused when we put uneven Load one time
  • dmurph May 31, 2008
    1 Year old Top Dryer/Bottom Washer, the drum is tilted. I'm assuming it was from overloading, as it is a very small washer. Is this a home handyman type fix? Will running it with a crooked drum cause more damage? Thanks for the help.
    Genius:
  • 1,554 Answers
You have likely stretched one of the side support springs or knocked it loose, you will have to open the side/back panels to see.
sometime you can just pull it out tilt the washer back and see it from underneath. disconnect power to live.
Posted on Feb 03, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Noisy spinning
First make sure that the load is balanced, if you are washing and spinning a dense load like trainers etc this can cause an imbalance. If you are washing a duvet cover or a pillowcase, make sure that the loose clothes washed with it haven't migrated inside the cover or case, this happens so easily. It is always worth checking that the support feet are all touching the ground when the washing machine is empty as this can cause excessive noise
hope this helpsKind regards ki
May 11, 2015 | Washing Machines
In the spin cycle at high rpm's the drum is making a load noise. Is it he drum belt? If so how can I replace it? I can't find a cutsheet on the parts list.
Hi there
Before you startreplacing partsin the machine, observe weather the washing is evenly distributed in the drum when it is working.
If the washing is not evenly distributed, there is a lot of noise and the drum does not go its rounds evenly.
good luck
kolbrun
Mar 10, 2012 | GE Energy Star WCVH6260F Front Load Washer
Loud noise from tub when on fast spin aquarius wma48 1400 spin
possible causes are
Overloaded Machine
Putting too many items in your washing machine at one time or washing larger items, such as a quilt, can cause your washing machine to occasionally make excessive noise. Laundry can get trapped around the agitator and will hamper its movement, causing it to work harder to spin. Stop the wash cycle and remove the excess laundry on top. Take big, bulky items to a laundromat or drycleaners to wash in an industrial machine equipped to handle such items. A washing machine is more effective at cleaning laundry when water and suds can surround the clothes and penetrate fabrics.
Defective Balancing System
GE washing machines have a balancing system that includes counterweights, springs and pistons that help to evenly distribute weight inside the wash tub. If any of the system's components break, it can interfere with the drum's rotation. Rather than spin evenly in the machine, the drum might be imbalanced up or down and produce a knocking sound. The noise might become louder and more persistent each time you do a wash load until you replace the faulty component.
Washing Machine Not on Level Surface
Place your washing machine on a flat surface, preferably a concrete slab. If the floor underneath the washing machine is sloped, even the slightest bit, it can cause the machine to vibrate when it spins and agitates. Place both hands on either side of the washing machine and try to move it. If the machine moves, then adjust its feet at each of the bottom four corners of the machine by tightening or loosening the bolts with a wrench until the machine is level on all four sides.
Jun 10, 2011 | Hotpoint Washing Machines
Celcus washing machine makes a banging sound when starting on spin and slowing down from spin
It could be caused by loose or damaged bearings or even damaged belt. You might have to replace worn out belt and bearings. Also find out if the washer is sitting on an uneven platform. Make sure the floor is even and the machine is not tilting.
http://www.washingmachineadvisor.com
Nov 22, 2010 | LG WM2077C XL Front Load Stackable Washing...
How do I fix my loose agitator on my GE washing machine? It makes a lot of noise.
i have a front loader and the drum is very loose. It dropped and wobbles alot when it's trying to dry
Nov 01, 2010 | GE WBSR3140DW Top Load Washer
Whirlpool washing machine makes alot of noise when spinning help
I assume you are talking about a loud thunking with the washer trying to walk around the room. This is usually caused by an unevenly distributed load of clothes in the drum. Try moving the clothes around, like a towel or jeans on this side and the same on the opposite side. If this doesn't do it, it is time to check the springs that anchor the bottom of the drum/motor/transmission assembly. There is an access panel near the bottom of the cabinet on either the front or rear side (depending on model).
Jun 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
GE heavy duty washer
make sure clothing is properly distributed in drum. Try this but need more info as to weather it spins and bump or weather or not it stays in one place and bump.
Mar 29, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
353 people viewed this question
Top Washing Machines Experts
