Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Sandisk cruzer 2 gb.
I have a sandisk cruzer 2 gb. I have been using it on Windows XP and stored excel and word files. Tonight it decided it needed to be formatted! I am concerned i will lose all my data. The exact message i'm getting is "the floppy disk in drive F is not formatted or has been formatted for a Macintosh" Any suggestions?
    Genius:
  • 3,422 Answers
There are a few possibilities. Bad drive. Bad (or incompatible)driver for the floppy drive. Bad controller. If it's a driver problem, the solution in Win9x is to disable the device in Windows. This forces the computer to use compatibility mode for that drive and it should work.
you can also read this it may help u out..
Clik here
Goodluck,
Dont forget to rate me as fixya..
Posted on Jan 29, 2008
  • 4,102 Answers
Hi this problem only occures by somehow getting a virus the only way you can use it again is by formatting it and removing the virus im not to sure if you format it that you can use a data recovery programme to get back the files you want.
If you are unable to acess the files on it then the chances are they are lost for good.
When you conect to comp does it tell you it needs formating as soon as you plug it in.
If this is the case then the virus has changed the format on the scandisk so you might not get your comp to read it again without formating.
But if you do format you will be able to use it again and should have no trouble.
Has somebody else tryd using it in a different comp like mac as this would change the format let me know ok
6ya staff
SOURCE:
How do you use a sandisk cruzer micro usb 2.0 flash drive
insert your 2 gb cruzer into a usb port click start all programs accessories open windows explorer my computer you should see your drive click to open it from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to scan disc then drop them
or if you are downloading from the internet once the program/files starts to download an option will open and ask where you want to save it or run it also browse click on the browse to save it to your 2 gb cruzer
hope this helps
Jul 10, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computer not recogniing my cruzer mircro 2 gb
You didn't' say which operating system you are using. Any current version of Windows (XP, Vista, 7) should be able to load a driver and not need a download for it. In any event, you can find the driver you need on the SanDisk website here:
http://www.sandisk.com/sandisk-support/driver-download-wizard
Apr 23, 2011 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
HOW CAN I PUT A FOLDER AND THEN A FILE ON TO A SANDISK CRUZER USB 2.0 4GB FLASH DRIVE ?
When plugged on a computer running Windows, the SanDisk Cruzer appears as 2 icons: a CD-ROM and a regular hard drive. The drive letters for the two are consecutive (ex: E:CD_ROM, F:SanDisk.
Any file or folders that you have to store on the SanDisk drive must be stored on the second device.
If the folder already exists on your computer, point to it with mouse cursor and right click. In the menu options look for the one that says copy and select it.
Open the Windows Explorer, locate theCuruzer icon that represents the hard drive part, click on it to open it. Point somewhere where there are no icons and right click the mouse cursor. Select the submenu Paste.
To copy and paste you can also use the keyboard shortcuts CTRL-C and CTRL-V
You can also open 2 explorer windows side by side, one showing the folder you want to copy and another the contents of the SanDisk drive. You can drag the folder to copy from the computer hard-drive and drop
Aug 04, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
LOST MY INSTRUCTION SHEET FOR SANDISK CRUZER 3 GB FLASH CARD
check out this link , and download the drivers or manual http://www.sandisk.com/sandisk-support/driver-download-wizard
Jul 07, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to make a sandisk Cruzer to operate with windows 98
This Cruzer driver package for the SanDisk Cruzer Micro is needed only for Windows 98. Windows Me, 2000 and XP already have the driver (if you are having trouble using the drive on these systems, then it is likely to be a conflict or problem in Windows - see the Windows Device Manager and Windows Help file for details).
After you download the Cruzer driver file, unzip the contents and click setup.exe to begin. Importantly, you should restart Windows 98 so the new Cruzer drivers can properly load into your system. Next, plug in the Cruzer drive and Windows will finish the installation. Restart your computer if needed.
Nov 07, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Can't open my sandisk cruzer 16gb
i have a 16 gb pendrive which is detected in my mac but not in any windows...............help me out here
May 10, 2009 | Electronics - Others
Sandisk Cruzer Micro 2.0 problem
Should show up in "My Computer" as a removable drive with letter designator. Then it is simply a matter of drag and drop to copy files using the mouse. If XP doesn't recognize the drive, put it in another USB port, and or try it on another computer. If it doesn't show up then, take it back to the store.
May 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Micro Cruzer reduced from 2.0 GB to 1.0 MB when reformated
Make sure you check to see if the File System is FAT32 instead of FAT or NTFS, this way you can have your 2GB back.
Try reformatting using FAT32.
Dec 10, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Top SanDisk Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
