Question about Canon CLC 1120 Color Copier
CLC 1100 toner peeling on 11 x 17 pages
My Canon CLC 1100 only has 40k copies but the 11x17 pages have the toner peeling off. We have increased pressure but still peels. Also colors are not as crisp as before
  • Anonymous Mar 22, 2014
    after printing the letters peel and flake off the paper. Its as if the ink is sticking to the wrong surface and gets stuck on a different part of the page
  • 4 Answers
If your using card make sure you tell the machine you are
Posted on May 07, 2008
  • 86 Answers
Phone me on 07764 303923 i am a trained engineer
cheers phil
Posted on Feb 13, 2008
  • philip davies Feb 13, 2008
    phone me i am a trained engineer for 26 years 0776 4303923
    your oil pad may need changing/fuser rollers-maybe worn
    advice is free
Try to do Auto Grad. You push the button (additional functions) next push ( Grad. A Adjst ) and just follow what the copier tell you to do.
Posted on Jan 29, 2008
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Canon CLC 1180 Copier Error Code: E071 0007
E071 / E072 / E073
Transfer Frame Connector
Poor Contact due to toner scattering around Transfer Connector
Replace Connector FG6 0948
TD Cleaner assy
Motor M8 being overloaded. Drive shaft from motor goes through long plastic bearings these were getting clogged with toner and oil
clean drive shafts
Transfer driver PCB
Static discharge onto transfer driver from peeling off old TD sheet too fast
Replace Transfer Driver PCB (FG6 - 2579) Remove old TD sheet SLOWLY to prevent problem.
Oct 21, 2011 | Canon CLC 1180 Copier
I just replaced my developer for all four colors. During the gradation adjustment, on the second and third test pages, I noticed pink streaks at top (about 1/5 of a 11x17 page). What could be the problem?
If you just replaced the toners then the problem is with the new toners. They will require that you print another 25 to 30 pages before the streaks will go away. Then you may continue to print without any issues. Let me know how I may continue to assist you.
Jan 28, 2011 | Canon CLC 5100 Copier
Error code e020 with sub code 140 on canon clc
This code refere the developing assembly locking plate.Please verify the plate mounted and the developer sensor,the toner hopper sensor or the toner hopper motor.
Dec 12, 2009 | Canon Office Equipment & Supplies
I have an old Canon 1150 color copier. The bottom drawer #2 dropped and can't feed paper properly. So I put 11x17 paper in drawer #1 which had 8x10 paper originally. Now the panel still shows drawer #1...
Is there a paper selection wheel or bar in the tray?
Some of the older Canon models have a dial (usually in the lower right hand corner of the tray) or a slider bar (usually on the left hand side of the tray) when you open it. That has to be set properly or the machine has no idea what size paper is there.
Dec 03, 2009 | Canon CLC 1150 Color Copier
Canon CLC 1100 E072 0202
E072 0202 means :
The transfer drum cleaner brush motor (M8) is faulty.
The polishing roller motor (M9) is faulty.
The motor drive system is subjected to an overload.
The attraction/transfer locking cam motor (PM7) is faulty.
The attraction/transfer locking cam HP sensor (PS8) is faulty.
The registration path driver PCB is faulty.
The DC driver PCB is faulty.
The CPU PCB is faulty.
The attraction/transfer looking cam HP sensor does not go '1' within 4 sec after the attraction/transfer locking cam motor has started to rotate.
May 06, 2009 | Canon CLC 1000 Color Copier
E020 sub-error 0273
go into service mode function or adjust and put in all the door spects take machine off then on do a graduation adjust
Sep 05, 2008 | Canon CLC 1180 Copier
Streaks on color copie
You must pull 2 sided glossy from the stack bypass and set on color paper.
Apr 11, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1120 Color Copier Logo
121 people viewed this question
old marine
old marine
