Question about D-Link AirPlus DI-714P+ (DI714P) 802.11b
Low speed or no connectivity when 2 comps share the home network traffic on DI-714p+ wireless router
I bought this second hand router with out knowing the old password in ythe set up process. So the wizwrd persistantly sends '401' error when trying to follow the set up steps and I can't finish set up. After resetting and restoring it to its original setting, we were able to receive signals and connect to internet, but it delivers a very low speed and gets disconnected from the internet when 2 computers are used simultaneously,or sometimes can't receive wireless coverage. Any upgrade software, or solution ? I'd appreciate it if you sent your advice to kamyaremtenan@msn.com , bec I'm leaving office. Thanks
  • Jon White
    Jon White May 11, 2010
    If you can log into the router and check the firmware version? It is usually under the Admin tab, you should see something saying firmware. If you could reply with that I might have a solution. Thanks.
  • 611 Answers
Check the firmware version and download the firmware and upload the it in the devices you get it
Posted on Jun 13, 2008
My acer one netbook is stuck on aquiring network address
Hi Boyer,
I got your issue, Since it says accquiring network address.
If Your comp if its win 7 Operating system
1. Click on start go to control panel--> go to network and internet and then click on network and sharing centre
2. In network and sharing centre in the left hand side click on manage wireless network
3. In manage wireless network, you can see the networks which you have connected before , right click on the network name and select remove network. In the same way remove each one of them, the screen should me empty. there should be 0 items.
4. Then go back to network and sharing centre and click on connect to a network, you can see your network name , click on the network and click on connect to connect to the network.
If Your comp if its win Vista Operating system
If Your comp if its win XP Operating system
1. Click on start go to control panel--> go to network and internet connections
2. Then go to network connections
3: You can see wireless network connection , right click on it and go to properties and go to the wireless networks tab
4. In wireless network tab, under preferred networks, if you see any network , remove it and then push ok
5. Then right click on wireless network connection and go to view available wireless networks
6. here you can see the network and you can connect with your password.
Please try this, im sure this will work
Thanks & Regards,
Prema
Oct 09, 2010 | Computers & Internet
I have got a Toshiba Satelite L40 - 17U, Window XP and i can't connect it my laptop to my wireless modern. i also would like to clean it or maight say erase everything and install everything...
Hi Dacosta,
I got your issue that you have trouble connecting with ,
Thanks & Regards,
Prema
Oct 06, 2010 | Toshiba Computers & Internet
Having trouble connecting to an AT&T 2-Wire 2701 HGB Wireless Router (DSL).
Hi John,
I got your issue that you have trouble connecting with the At &t wireless modem ,
Thanks & Regards,
Prema
Oct 06, 2010 | Computers & Internet
Wireless security
You can disable the network card to block all Internet access.
This doesnt help though when you want to check your email etc.
Try turning off Windows Automatic updates, and any antivirus automatic updates, these two things are the bane of wireless broadband users as it will use most of their data before they even realise.
Aug 21, 2009 | Computers & Internet
Want to know the pre shared key
If you don't know your pre shared key or forgotten it. You need to access the configuration page of your router and create a new network name and a sign a new network key or pre shared key. Create the profile of your SSID/Wireless network connetion under wireless settings.
Jan 17, 2009 | D-Link AirPlus DI-524 Wireless Router
Vista OS can't connect wireless to Dlink DI-614+ rounter
yes it does but what exactly is this it's your comp that's not connecting to your wireless network..so here try these steps...
first click start>click in start search>in that box type in services>it gives you an option of services on the same start menu at the top click on that...
it will take you to a new screen that says services at the top on that screen you need to scroll down at the bottom and look for wlan auto configuration rt click on it and click start if start is greyed out press restart....
close services down..
click start>click connect to form the start menu> and check it gives your network name in there .if it says anything like no network found in range. pls make sure that wireless switch on your laptop is turned on...
if still you're not able to connectr it's a concern with the drivers of wireless adapter on your comp genrally on new comps its quite common get the drivers reinstalled....
Feb 18, 2008 | D-Link AirPlus DI-614+ Wireless Router
WEP Encryption
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
WEP Encryption
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
D-Link AirPlus DI-714P+ (DI714P) 802.11b Logo
132 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
