SAMSUNG HL-S6767W will not power on.
TV will not power on, Lamp and main board was replaced late last year.
I can get it to turn on and it will run great, But when I turn it off and try to turn it back on I get a sound and No Picture. I will have to have it shut off for over 12 hours before it turns back on....
  • 2 more comments
  • Anonymous Jan 29, 2008
    If this done not work could it be the Optic / Engine?
  • Anonymous Jan 30, 2008
    Saw the TV, and spoke to client, Unplugged set and banged it like you said...??? What happens is when TV is turned back on....
    Sometimes gets sound only
    Sometimes gets nothing....Nothing...
    What boards should I replace.
  • Anonymous Feb 01, 2008
    Hey there Cool Guy,
    I am a new technician and was testing this site for help when I need it. I Called my buddy who owns a TV Repair Shop, and without blinking an eye said it was the Optic Block, I will replace it and respond.
  • Anonymous Feb 09, 2008
    I was right, It was the Optic Engine,
    I replaced it and it's working Great !!!
    Joseph
    Genius:
  • 3,422 Answers
I think the controller IC chip has gone kaput. BUT, it could also be just a software glitch. So, try a hard reset and see if it solves the problem. If it does not you will need service. If still under warranty the factory service center should take care of it.
Do a hard reset by unplugging the power cord, as you have been doing, but a complete reset requires the power to be unplugged for at least 4 hours. Then when you turn it on all the internal soft codes will boot up to factory default settings.
Also, just in case there are loose connections or cold solder joints at the root of the problem, with your hand or fist go around and smack on the cabinet front, back, sides, etc. to see if that will wake up any dead connections.
Let me know the outcome
Dont forget to rate me as fixya..
Posted on Jan 29, 2008
  • 2 more comments
  • Priya darshan Feb 01, 2008
    Common parts are still available, but custom parts such as a power transformer and certain Integrated circuits may not be.
    Because there is a very high statistical probability of another failure
    soon after the repair. Why? Because there are hundreds/thousands of
    parts in the set and millions of transistors inside the ICs. They
    follow a statistical pattern of failure and one failure means another
    one could come any time.
    If you were a technician and could fix it yourself - or had someone in
    the family who could fix it for free or for parts costs it might be
    worth it.
    this sounds like a bad power supply. a repair cost will range around
    120-200. samsung tv's are not what everyone thinks they are. they do
    not last long. i would not have it repaired. invest into a newer tv.
    pay a little more and get a sony it will last longer.
    good luck :)
    ok..
    My best wishes to you hope ur TV gets well soon..
  • Priya darshan Feb 09, 2008
    congrats finally your problem is solved if you have any other problems in future please ask me..
    Goodluck once again please don't forget to rate me as fixya for my efforts..
6ya staff
SOURCE:
Samsung DLP HLS6767W chirping???
change the color wheel its worn out the chirping or whirr comes from the color wheel in the light engine u will need a tech to replace it
Jul 11, 2013 | Samsung HL-S6767W DLP TV
CHIRPING SAMSUNG PROJECTION TV
Chirping is set is in shutdown---most likely in High voltage area of set.
Jun 11, 2012 | Samsung Televison & Video
I cleaned out my Samsung hl-s6187w and put everything back together and now it doesn't turn on. It makes a beeping noise like fast morse code and keeps cycling the power trying to turn on. The ballast gets...
Tv projection lamp inside the tv less than 2 years or so?Yes than the tv projection Lamp is good.You have this tv like 3 or 4 years already?The tv colors wheel even have been replace at leat once?No the tv probally require replacing the colors wheel these tv have to replaced the colors wheel every now and than.
Apr 14, 2011 | Samsung HL-S6187W 61 in. HDTV
What is causing my picture to darken on my samsung 60 inch dlp tv
Most likely the tv projection lamp life are ending.The tv projection lamp been inside this tv like 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours each day?The tv projection lamp life are ending,require a new tv projection lamp.
Jan 04, 2011 | Samsung HL-S6767W DLP TV
My samsung hl-s6767w dlp keeps shuting down. and tehree blinking lights come on
this may be related to the power board or main board or even both.
Jul 29, 2010 | Samsung HL-S6767W DLP TV
TV wont turn on
a bad power supply is most likely cause of this. Other possible cause is bad main circuit board.
May 03, 2010 | Samsung HL-S5086W 50" HDTV
Samsung hl-r6178w 3 blinking lights
The power board ic converter is dead.
U can tries to go to the web buy the part and replace it yourself.Or hire the repair man part and labor $575
Aug 13, 2009 | Samsung HL-S5087W DLP TV
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
