Question about Nintendo DS Lite Console
No power power light comes on but screen flashes and system shuts off. its not the battery
  • PlutoPlops Jan 30, 2008
    Power light comes on but neither screen works. Nintendo DS Lite. Once when trying it out the screens came on but then went off again and nothing since. I suspect it has had some vigorous handling by my young son but nothing is visibly damaged.
Thanks Lamylamb. I went and checked out the slots as you suggested but unfortunately there was nothing jammed. I have since sent it off to Nintendo and they have replied with a quote for a new circuit board AU$95. I think their service was quite efficient. It seems that young son was too rough with the device and broke it.
Thanks for your help.
Posted on Feb 11, 2008
    Scholar:
  • 113 Answers
Make sure nothing is jammed into the game slots!!!! this will cause it to cross, and shutdown. also make sure u switch it on without the game inserted. and try different game card.
goodluck, lamby
Posted on Jan 31, 2008
6ya staff
SOURCE:
My son's DS Lite stopped working last night. The unit was working fine and the battery light turned red so he put it on to charge. After about an hour the light was green so he tried to start the console...
It sounds like the battery is dead. You can order a replacement battery direct from Nintendo at http://store.nintendo.com/webapp/wcs/stores/servlet/ProductDisplay?productId=108205
Jan 27, 2014 | Nintendo DS Lite Console
When the power is turned on the screen lights up for approximately 2 seconds then the power shuts right back off..... The batteries are good and even were replaced just as a precaution. What could our...
What color is the power light when the system shuts off?
    Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged.
    Blue: If the power light is blue when the system turns off, then there appears to be a problem with the system and it will need to be repaired.
I understand you have replaced the battery... make sure its a genuine nintendo battery and charge. Also the port could be damaged or the ac adapter... take a good look at both for damages.
The port should not wiggle on the DS and should be solid.
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Jun 29, 2011 | Video Game Consoles & Games
Battery? console has no charge when plugged into wall outlet I push power button blue LED comes on briefly , then red flashes 3 times, and the yellow LED lights up along with the health warning on the...
    If the orange recharge indicator light blinks while the system is plugged in and charging, then it is likely that the battery is not installed properly.
    If you have ensured that the battery is installed properly but the orange light still blinks, check to make sure that the battery is a licensed by Nintendo. The only licensed Nintendo DSi battery will have the model number "TWL-003" (Nintendo DSi) or "UTL-003" (Nintendo DSi XL) and will display Nintendo's logo.
    Call 1-800-255-3700 if you still need help.
Jan 27, 2011 | Nintendo DSi Matte Blue Console
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
My sond ds lite wont turn on and the charge light
Yes, this problem is normally caused by one or both of the fuses have blown on the logic board.
Feb 17, 2010 | Nintendo DS Lite Console
Acer 3100 laptop lights on fan on slow but no screen
Remove the battery and disconnect the Ac adapter from the laptop. Press the power button and hold it for 10 seconds.Reconnect only the Ac adapter and power on the laptop.
Post back if the above solution doesnot work , it could be bad video card driver.
Thanks for using fixya
proton
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
