Question about Palm TX Handheld
The palm powered icon
Stays on tried soft reset did not work . how do i do a hard reset? is their something else i should try before the hard reset.
    Problem Solver:
  • 10 Answers
To do a hard reset, hold down the power button, press the little reset button, release it, then release the power button.
Make sure you back up your TX first.
Posted on Feb 24, 2008
6ya staff
SOURCE:
Palm Treo 700W Smartphone is stuck on speaker phone
Soft Reset
A Soft Reset stops all active (or open) programs and "reboots" the handheld. When the Treo powers back up, you'll start with all programs closed and the unit will be ready to use. The soft reset is intended to reset the Treo if it is malfunctioning or has become bogged down.
The Palm Treo 750 can be soft reset by quickly pressing and releasing the tiny red button beneath the miniSD memory card door:
diagram.jpg Hard Reset
A Hard Reset wipes the internal memory and returns the Treo to its factory specs, in effect returning the Treo 750 to the state it was in when you purchased it. All data entered, preferences set or software installed on the Treo after purchase will be lost after a hard reset and will have to transferred or reinstalled via ActiveSync / Windows Mobile Device Center.
power_button.jpg The Palm Treo 750 can be hard reset by pressing and holding the power button (seen left) while at the same time pressing and holding reset button beneath the miniSD memory card door. Press and hold the two buttons until the screen completely fades. When the screen returns, you'll be given the option to "Erase all data." Select Yes to complete the hard reset. The Treo will now be as it was when it left the factory and you can start fresh. You may have to perform a soft reset after the hard reset to get the unit to power on.
May 11, 2008 | Palm Treo 700w Smartphone
My palm just displays ''Palm Powered'' Tried soft reset
Have you tried a hard reset? Just remember a hard reset will delete everything on your device. All your data will be deleted, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything. Here is a link with the directions:
http://kb.palm.com/wps/portal/kb/na/tungsten/e/unlocked/solutions/article/42094_en.html#tx
If that doesn't work then try the free palm chat service they offer. Here is a link to that:
http://kb.palm.com/wps/portal/kb/na/tungsten/e/unlocked/solutions/article/43473_en.html
Nov 13, 2009 | Palm Tungsten E2 Handheld
Palm z22. wont startup without holding the up arrow key and doing a soft reset. Then Task icon wont load and some of the other applications wont load
Try doing a hard reset. Warning: A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything.
Here are the directions:
  1. Press and hold the Power (on/off) button on the front panel of your device.
  2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  3. If you see a progress bar (see below), keep holding the Power button.
  4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Note: A hard reset does not delete the current date and time. It does restore other settings to the factory default.
The progress bar On some devices, you may see a Palm or palmOne logo and a progress bar first. Do not release the Power button until the second, circular Palm Powered logo appears. From there follow the on screen directions and then do a HotSync. Best wishes
Oct 25, 2009 | Palm Z22 Handheld
Z22 palm handheld touchscreen won't respond - i've done soft reset -- several times -- used the 5 way to bring up the touchscreen -- tapped and nothing happened.
Hi, Try doing a hard reset to see if this will correct the problem.
Hold down the power button and at the same time use the tip of your stylus or any other non sharp item and press the inside the reset hole on the back of your palm.
When you see the Palm power logo appear you can let go of the power button and also the one on the back of you unit.
It will display a message asking if you want to do a hard reset and that it will erase all your data. select yes by hitting the up part of your 5 way button on the bottom of your unit. This is the one you use to navigate around your palm screen. After it resets you wil then be prompted to reset the screen by tapping the targets. If it works great. If not then you have something wrong that needs to be looked at. Before you send it in go to:
www.palm.com.
Select pda and then your model. From there go to the support screen and do a live chat. This is free and they may be able to live you some help. Best wishes.
Sep 19, 2009 | Palm Z22 Handheld
Can't reset my password on my Palm Z22
If you have forgotten your password you should be able to use the password hint to figure out what it is. You can try a soft reset to see if that will clear the password but I am pretty sure this won't help. To do a soft reset use the tip of the stylus or something pointed like a paper clip and inset it in the hole on the back of your palm pilot. This will make the unit reset it's self. If this doesn't help then you must preform a Hard rest to continuing using your hand held. You need to make sure that you have all your information backed up on your computer as a hard reset will erase everything on your hand held. Here are the steps to do a hard reset:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
3. Wait for the Palm Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your handheld do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your handheld to finish the reset and show the touch screen.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your handheld. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. You should be able to reset a password if you want one. Best wishes....Hope this helps.
Aug 27, 2009 | Palm Z22 Handheld
When trying to sync, error message reads (sys 0505)(0,841).What can I do? For Palm TX handheld
Try to perform a System Reset (see article linked below). If it works to break the loop, you should then be able to delete the offending "My Palm" software and perform a Hotsync to backup your data to your desktop.
If that doesn't break the loop, you'll have to perform another Hard Reset. Sometimes, a Hard Reset takes a couple of tries to get it right, since it's easier to do it wrong than to do it right.
This article discusses the various types of Reset for different Palm devices:
http://tinyurl.com/zlwza
Until you break the TX out of its loop, you won't be able to get the data from it.
To see the Palm OS version running on your TX, enter the Menu, select Info, then Version.
To Get Out Of A Loop:
  1. Perform a SYSTEM RESET by doing the following:
a) Press the UP Button
b) And THEN press and release the RESET Button
c) When you see the second Logo (Palm Powered) release the UP Button
d) Now check if your SYSTEM RESET worked by going to Beam Receive. If it goes back to Off even after you put it to On it means you were successful
2. Now Perform A SOFT RESET by pressing and releasing the button in the back once
  1. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
  1. If a soft reset does not break it out of the loop, you may need to try one of the other resets below.
  1. Do an INCOMPLETE HARD RESET by holding down the power (on/off) button on your device.
  1. While holding down the power button, Press and release the reset button on the back of your handheld device
  1. Keep the power button pressed and release it when the “Palm Powered” logo appears.
  1. A message will now appear warning that you are about to “Erase All Data”. And this will happen if you press UP or DOWN.
  1. Instead you press left or right to begin a soft reset, leaving your data intact.
  1. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Sorry this was so long, I tried to put everything down that might help you.
Aug 03, 2009 | Palm TX Handheld
Palm m515 frozed up when powered on.
Did you install something rare at your palm??? Is your palm Sayin "Fatal Exeption" when you Reset it??? If you install something rare and after that your palm is saying taht you can...
Do a soft reset:
Reset it normally... If after that your palm show again that message you can;
Do a warm Reset:
Pres de up scroll when resseting.. when you so the Palm logo you can stop press the reset botom... There you will see the configuration screen... If it is not more the "fatal exeption" message you can uninstall what is doing the problem... you can hot sync your palm now... after that... do a soft reset and-If you uninstall what is doing the problem- you are not going to saw any more that message... if it is not resulting...
Try to do a Hard Reset
Do a warm reset and copy all you important files or programs to your stick memory...
then when pressing reset botom pres the on-of screen botom.... when you see the palm logo you can stop presing on-of screen botom.
bye.
From paraguay... luis-c
(sorry for my english... im stilll learning)
Apr 14, 2009 | Audio Players & Recorders
MY TREO 650 KEEPS TRYING TO HOTSYNC(and its not connected to computer)
Did it actually reset when you did a hard reset ..or does it stay powered up?
Dec 31, 2007 | Palm Treo 680 Smartphone
Palm TX Handheld Logo
98 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
