Question about GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 Microwave Night Light Inoperative
Our GE XL1800 night light won't function. Sometimes the light does come 'ON', but then goes out after several minutes of being lit. The bright lights for the counter top works fine. So it shouldn't be the bulbs. Any idea of what the problem is that is causing the night light not to operate?
  • John Fox
    John Fox Feb 03, 2008
    The information provided didn't help. The bulbs have never been replaced or removed from the unit. As stated in my posting of the problem, the night lights do operate occasionally, but very infrequently. I was very aware that power must be disconnected from the unit to prevent the control panel from being damaged while changing the bulbs.
    In the unit's user manual provided by GE, it is specifically noted that power must be removed from the unit before attempting to change any of the bulbs. The way GE mentioned this in the manual made it clear, at least to me, that this was more than just a safety issue while replacing bulbs. However, as mentioned earlier, the bulbs have never been replaced or tampered with on the unit, and they do work at times.
    Thank you for the attempt to help. Perhaps the control panel developed a problem on its own or has an inherent problem. That would make sense as to why the night lights are intermittent in operation.
    Thanks again and have a nice day!
  • harv123 Mar 18, 2008
    microwave is only 5 yrs old and wont come on. open the door the light came on, then went off. need help
  • GE Master
  • 9,098 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 03, 2008
  • William Miller
    William Miller Feb 03, 2008
    Right.
    Sorry, I thought I qualified the remark well enough when I said it "often" occurs when a bulb goes out or shorts.
    I didn't mean that was always the cause.
    Either way, I suspect the control panel, and we'd be happy to repair it for you.
GE Spacemaker XL1800 not working?
  • Open internal fuse
  • Magnetron failure
  • Faulty door interlock
  • Faulty control board
Feb 05, 2018 | GE Microwave Ovens
Kitcehaid ykhms155lss-0 night light does not dim
We see and repair this a lot. The problem is on the controller assembly.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Since the circuit boards are no longer available, repair is the only option. Details are here.
Dec 02, 2013 | GE JVM1650 1000 Watts Microwave Oven
Microwave Cooktop / Night Light not working
I would check the door switches with a digital meter, set to ohms, disconnect one wire from switch and test for open and short by pressing door switch, if you hit one that tests the same when pressing and releasing, switch should be replaced.
Mar 06, 2012 | GE Microwave Ovens
I replaced the outside/night lights on my Kenmore microwave and the lights stay on. They are 3 settings, high, night and off and they do not cycle through, they are always on and won't shut off
This is a shorted relay on the control circuit board, which we normally repair for $39.95 nationwide.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 17, 2011 | Kenmore 63792 Microwave Oven
I have a GE Spacemaker model JVM140H 002. The night lights work, but the main lights do not work, I can hear the relay clicking and the night lights go out.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
Dec 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Night Light on Microwave Oven
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 19, 2008 | GE XL1800 1100 Watts Microwave Oven
Lighting Problem
Mar 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 JVM1870SF02
I have the same problem on a Jenn Air. Did you get an answer?
Oct 03, 2007 | GE XL1800 1100 Watts Microwave Oven
Glass Surface Light Lens Cracks from Halogen lights use
The lights do get very hot, so they must be a sufficient distance from the lens. Was there an instruction sheet with the new lens? You may need to adjust the sockets upward. You might call a local GE-authorized servicer to see. Concerning the vent fan, this is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 06, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
900 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
