Hotpoint WMA58 Front Load Washer Logo
Anonymous Posted on Dec 30, 2009
Hi. My wma58 is leaking from the detergent drawer.I have cleaned away any residue which may stop drawer closing properly problem persists can anyone help thanks
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
492
Points
I removed top panel of machine took out drawer and removed screws allowing me to pull drawer compartment back slightly from front panel. Here i found more detergent residue which i couldn't see before.after cleaning this and refitting everything problem was solved.
1helpful
Detergent doesn't dispense from the drawer
Remove the drawer and clean it thoroughly, also clean the drawer area of any detergent residue. Check that there is water flow into the drawer from the inlet nozzles above it.
Make sure you are putting the detergent in the correct drawer compartment. If it still persists further investigation of the feed in and out pipes will be required..
Soap residue remains in the detergent tray. Why.
Residue builds up no matter what the manufactures claim.
Once in a while, remove the detergent drawer. Pull it out gently until it stops. then push down on the black tab at the washing machine end of the drawer and while pushing down, pull the drawer totally out. Take it to the sink and wash it out with an old toothbrush.
1helpful
Servis wp1249f2w leaving powder in the drawer each time, any solutions?
Stop using powder. Use liquid instead and see if that makes a difference.
First off. Before changing the detergent clean the residue of the powder from the tray.
Another thing to keep in mind is the type of detergent.
You want HE detergent. The reason for HE is it uses less and leaves nothing behind. ( HE stands for High Efficiency detergent.)
Hope this helped.
The detergent dispenser on my Malber P31 has become detached from the functions panel. The plastic has snapped away gradually from each of the 7 screws. Can it be fixed?
At some point the support came loose and when the drawer was pushed in at probably broke more of the plastic away from the mounting screws. The only way to fix it properly is to replace it with a new one.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
What brand of detergent should i use
I have had good luck with the powdered dishwasher detergent from Wall Mart's brand Great Value.
Before I switched to this brand I had to clean the washer drawer several times because the detergent I was using was not dissolving properly and would leave a residue in the bottom of the drawer and on the dishes.
1helpful
The fabric softner is not draining during the cycle
Normally caused by undissolved soap residue. Switch off machine from mains, Remove detergent drawer from washing machine, there might be a small plastic clip that need to be levered by hand before the drawer can come out completely. Soak detergent drawer in a tub of water, rinse under tap and wash thoroughly until all soap residue has been washed away. Replace drawer.
Both dish drawers are leaving a chalky dried on residue on the dishes. I ran a cleaning detergent in both drawers, made sure salt in water softener was filled, checked filters, and they are still leaving...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
2answers
Water is leaking out of the detergent drawer. It
i would say the outlet from the bleach area is blocked clean out drawer unit
3helpful
Dispenser tray removal
hi, nikoltheis! i'm not sure if we have exactly the same model, but it should be pretty close. here's what my user's manual says:
Detergent and fabric softner may build up in the dispenser drawer. Residue should be removed once or twice a month
- Remove the drawer by first sliding the safety latch to the right, then pulling the drawer out until it stops.
- Reach back into the left rear corner or the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
- Remove the insert from the bleach and fabric softner compartments.
- Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softner residue may indicate improper dilution or that more frequent cleaning is required.
- To clean the drawer opening (the empty area left behind when you remove the drawer) use a small brush to clean the recess. Remove all the residue from the upper and lower parts of the recess. (The picture shows this being done with a tooth brush.)
- Replace the insert pressing "X" to lock it in place. Return the dispenser drawer.
Detergent trouble
hi there,
sounds like the detergent dispenser is not working properly.
are the rest of your dishes clean? in other words, is there any food residue on them?
check the dispenser and make sure that there is nothing visibly wrong with it.
if the problem still persists, replace the dispenser.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
