Question about Panasonic PT-51HX41 51" Rear Projection Television
Convergence Help please.....?
Hi, quick question to all the experts on here. I read through this forum recently and determined what the issue was with my TV. I needed to replace the two IC Convergence Chips (think that is what they are called). Anyhow, I replaced them today and now setting the convergence on the tv. When I go into the tv settings (not service mode), the first convergence setting is a large green + sign. Is the goal of this setting to get the + in the middle of the TV? I took some string and made an X on my tv to find the middle. I then lined up the green + sign so the center of the + was on the center of the X (the string). After that, then I lined up the blue and red, and then went to convergence 2 settings and made all the + signs look as good as I could get. TV picture looks fine to me, but my guide through the cable box seems to have a little ghosting. Just wanted to make sure the first step is finding the center of your screen with the big green +.
Also, is there an easy way to determine if the lenses need adjusting. I did move the blue when I had the original blue convergence issue and noticed it will make the blue more blurry, or not so blurry. But is there a screen or some mode to put the tv in to adjust these lenses so I can be assured they are as crisp as they can get? This TV has been hauled from a few houses in the past and I just have to think they have shifted slightly.
Thanks for any help someone can provide. I appreciate this forum soooo much. Reading though here saved me several hundred dollars with diagnosing the two IC chips that needed replacing.
  • eric01mc Feb 05, 2008
    premtech... thanks so much for writing a response! Figured out where teh ghosting was coming from. Comcast Cable box.... glad you told me to drop that out of the picture. No ghosting on the text from the TV menu or DVD menu, but once I put that Comcast Cable box back in the loop, their online guide has ghosting on the text.
    Thanks for the help!
  • 934 Answers
The collar adjustments on the top of the crt assembles are simply focus... If you have never removed the crt's it is HIGHLY unlikely you will need to rebalance the crt in your endeavor to set convergence....
Next - never, never, never use some intervention signal to set convergence... Did I get enough nevers in there... Hook up a dvd player or good vcr and start with that as a picture... Set yor collars if they need adjusting.. At this point, and from what you've described just readjust your blue collar back to what you had...
Next, go back into the multi-point convergence and check to make sure you have each quadrant set to as close as you want... Then bring the picture back up and re-check.. If there is any ghosting when you hook this back up to your sat box or cable guess where it's coming from.. You got it, garbage in - garbage out...
With the digital convergence on that unit there is no need to jig the set. (ie: use a string to find center...) Some set require an overlay but their multi-point isn't nearly as complex as that unit...
In short, if your colors align to a white cross you got it!!
Bill
Posted on Feb 03, 2008
Please help me clear an error code 17 on my Yzf r6 2008 It's a straight system, the part that it corresponds with has been removed previously.
Hi, Nathan for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/47022-r6-service-manual-fault-code-table.html
http://www.r6-forum.com/forums/58-exhaust-fuel-delivery/90975-code-17-question.html
http://martin.lipinsky.cz/r6/files/LIT-11616-21-61.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 24, 2015 | 2008 Yamaha YZF-R6
DC44 Brush spins when not using vacuum
Hi there, it's Jack at Dyson.
The issue you've described sounds very odd, and we'd like to take some further details. If a replacement part is needed, we can also confirm if your machine is within our 2-year warranty period.
When your machine is fully charged and easily to hand, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to run you through some quick diagnostic checks to help determine the best course of action.
Feb 10, 2014 | Dyson DC44 Animal Cordless Vacuum
My Dyson DC31 runs for a few seconds then cuts out and won't work at all. It is fully charged. We bought it just over 2 years ago and it has worked perfectly until now. It is clean and has no apparent...
Hi Jean, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC31. If it cuts out in use when it's fully charged, we'd need to take you through some quick diagnostic checks when you have the machine at hand. This will help our experts determine what may be causing the issue.
Please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 04, 2013 | Dyson DC31 Animal Bagless Handheld...
Yamah bt1100 speedo
Hi, Gilbert you may have a faulty sensor for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.r1-forum.com/forums/102-00-01-r1-mechanical-help/330687-speedo-not-reading-correctly.html
Repair Yamaha Star Speedometer Odometer Not Working
Yamaha BT1100 2002 Service Manual
YAMAHA BT1100 Owner Manual
Sep 02, 2012 | 2002 Yamaha BT 1100 Bulldog
Iv recently removed a Datatool system3 alarm for my 54 plate r1 now I can't get it to fire up. Not sure if its the immobiliser any help would be appreciated, thanks, Alex.
Hi, Alex for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/101-98-99-r1-mechanical-help/457122-data-tool-alarm-removal.html
http://www.sonicsideshow.com/blog/-how-to-bypass-a-datatool-system-3-motorcycle-alarm
2004 2005 Yamaha YZF R1 Service Manual R1 Moto Data Project
Jul 09, 2011 | Yamaha YZF-R1 Motorcycles
The Dyson17 Animal makes a loud whining noise when running. The filter was cleaned recently. It also seems to run hot.
I'm sorry to hear you're having difficulties with your DC17. Since it will be difficult to determine the exact cause of the noise you're hearing online, it's probably best if you get in touch with us directly. One of our experts will be happy to provide you with the support you need to resolve this issue as quickly as possible.
You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as as possible.
Kind regards,
Jack
Jul 01, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My 2004 R6 has a problem with the cooling system. The orange light meaning engine management problem is on and the temp read out is always saying lo
Hi, G_willis61 you may have a faulty temperature sensor for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2001 r6 only shows LO and no number for temp help SoFlaSportbikes com...
http://www.r1-forum.com/forums/4-mechanical-help/254395-98-r1-digital-display-reads-lo.html
2003 2004 Yamaha YZF R6 Service Manual R6 Moto Data Project
Feb 26, 2011 | 2004 Yamaha YZF-R6
Rca d52w20 convergence aspec ratio and sound problem
Did you replace small fuse beside fly back?. resolder fly back pins. Maybe liquid coolant alround chassis or yokes.
Apr 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba model 61HX70 convergence issue
It is a good possibility you damaged something on that PCB that had the IC's, I like to use an upgraded chip the STK394-160e that is designed for HD signal stresses. I dont know why they ordered the convergence board but I suspect it would have been ok, there are also 2 jumpers that need soldering JW10 and JW50 that supply power to the chips and they REQUIRE resoldering or it will fail again. Might try reseating the RED CRT board, check for cables that you may have unhooked to see if they are not seated in their sockets properly, double check every wire you unhooked, Make sure you used a Silicone Heatsink Compound on to the back of the IC's. I dont know what all you unhooked, but check the wires going between the CRT Boards. Check for cracks in the boards to make sure they werent flexed to much. Good Luck.
Sep 09, 2006 | Toshiba 61HX70 61" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
