Question about LG RUMOR Cellular Phone
My son Dumped some kind of liquid on my LG Rumor and now it is white screened.
  • LG Master
  • 6,993 Answers
Please take note; once a phone drops into water or any liquid, first thing you need do is to remove the battery, get a phone screw driver, loose the phone and dry the phone board with bulb or any heat.
The essence is to dry the water totally from the board, because if it dries itself, the phone board will get rust and phone might not work properly again.
Back to your phone, I think the liquid as entered your screen and its not dry yet, that's why its white.
Put off the phone, remove the battery and leave the liquid to dry on the screen or put is near a very light heat and the liquid will gradually dry off.
Try it, it will work.
Take care.
Posted on Dec 30, 2009
SOURCE:
Hey i have an lg rumour havent had it more than a
does it have water damage at all? also have you ever dropped it? because when my rumor had water damage, the screen went white.
Aug 27, 2009 | LG RUMOR Cellular Phone
The LG Rumor is blinking white every 5 second on the screen
Have you updated your firmware? You may need to do that.
Go to Setting/Tools from the menu, then tools and then update firmware.
If this doesn't work, you need to take your LG Rumor back to the store were you bought it. If you have insurance they will fix it or give you a new phone.
Jun 19, 2009 | LG RUMOR Cellular Phone
White screen on LG rumor
take out the battery and let it dry out for like a day or two........ if this doesnt work i dont know what else to tell ya cas its worked on my past phones
Jun 01, 2009 | LG RUMOR Cellular Phone
LG Rumor White Screen
The flex cable that connects the two pieces that make up the phone are worn out or disconnected inside. you need to open it up and check it out. Go to http://www.youtube.com/watch?v=hNaCfrqqnd0
Apr 11, 2009 | LG RUMOR Cellular Phone
White screen
defect lcd as long as there is no black lines indicating the lcd popped, your service provider should be able to replace the lcd at a repair location
http://storelocator.sprint.com/SL2/Default.aspx
Apr 09, 2009 | LG RUMOR Cellular Phone
My son's Rumor phone screen is blank after the phone turns on.
If the LCD is white/and or garbled then "YES" this is a known issue.
First locate the Sprint Insignia (Label on the back of device) to check manufacturer date. You will notice two bar-codes one entitled ESN HEX. At the very bottom of the this bar-code is a combination of numbers and letters. The first two numbers are the manufacturer's date (Example: 801). The first number stands for the year and the second number signifies the month. The example above indicates January of 2008.
Most LG Rumor Series manufactured before April 2008 suffered with white/garbled screen. This is a problem with flex cable; simple fix.
Just visit your local Sprint Service Center for this specific repair. Regardless if you have insurance or not, this defect is still covered. Thanks.
Mar 24, 2009 | LG RUMOR Cellular Phone
Keyboard doesnt work on lg rumor phone
Take the phone to a mobile service center and ahve them replaced teh keyboard for you.
Nov 19, 2008 | LG RUMOR Cellular Phone
LG Rumor Problems
This is a known issue with the Rumor. If you take your phone into a sprint repair center or call technical support, they will most likely repair or replace it for free.
Oct 05, 2008 | LG RUMOR Cellular Phone
LG Rumor Screen
I'm sorry. This isn't an issue that you will be able to solve yourself. The problem lies with the ribbon cable in the phone. You see the ribbon cable wears down causing the phone to "garble" or white out and will need to be replaced which can only be done at a repair center. This problem shouldn't cost you anything even if you don't have insurance or a service plan because this is a LG and Sprint known issue.
Sep 28, 2008 | LG KG800 Cellular Phone
LG RUMOR Cellular Phone Logo
102 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
MERCY GATHUA
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
