Question about NetGear WGR614 Wireless Router
Router Password I have a Netgear Wireless Router WGR614 v6. and I need to set up portforwarding to enable me to use Amateur Radio over the internet ie Echolink. I need to get into Netgear Smart Wizard as Echolink requires you to forward the 5198-5200 ports. I go into www.routerlogin.net and get the Authentication Required box, I then put in admin as username and password as the password, I have also tried 1234 for the password but nothing happens, I just keep getting the Authentication Required Box. I have even put the the default ip address of the router ie 192.168.1.1 and the Authentication Required Box comes up but it will not accept admin password or 1234. Have you any ideas how I can find what passwords are set for this router, I do not really want to press that reset button yet. Thank you for your help regards John Youde
  • sales178 Jan 30, 2008
    Dear Ktquinn
    Many thanks for your info which I have tried, but it still does not allow me to get into Netgear Smart Wizard. I think you are right I will have to reset the router.
    Take Care
  • Anonymous Mar 26, 2014
    trying to set up new asus router and it says authentication required
  • 52 Answers
Try admin and admin again for password. If that is not it try leaving the password box blank. Good luck Are you sure you did not change the password when you set it up the first time. If you did you have no other option than reset.
Posted on Jan 30, 2008
Cannot install netgear router WGR614 N150
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 03, 2011 | NetGear WGR614 802.11G WIRELESS...
After doing a reset and a 30-30-30, the router is not sending out a wireless signal.
Hi bamavincents,
If you reset the router the settings will return to its factory state so we need to check if the wireless settings is correct. Listed below are the steps on how to access the router and the settings that we need to change or check.
- Make sure the router is powered ON and operational.
- Check if the Wireless Router Radio is enabled. A wireless adapter can only connect to an AP or wireless router if the wireless feature of the router is enabled. .
- Open an Internet browser and login to your router's setup page. Type 192.168.0.1 or http://routerlogin.net on your Internet browser. Then type admin as the username and password for your password. Password is case sensitive.
- Go to Advanced menu and click Wireless Settings.
- The Enable Wireless Router Radio box must be checked to enable wireless function on the router and Make sure the SSID is being broadcast and not hidden.
- Make sure that the wireless switch of your computer is ON before searching for your Access Point or SSID. If possible try another computer if it will detect the wireless signal. If after all steps and still not sending a signal there might be a problem with the router.
Thanks for usin Fixya.
Feb 05, 2011 | NetGear WGR614 Wireless Router
Pasword protect my router how?
There are two kinds of password protection for your ROUTER;
(1) The Web Interface can be password protected by changing the default password
(2) The Wireless connection password (encryption)
Which one do you want enabled to protect your router?
Jul 27, 2010 | NetGear WGR614 Wireless Router
How do I install it?
First connect your router to computer with ethernet cable.
Then you can access it with following default link.
http://192.168.1.1
or
http://192.168.0.1
Type user as "admin" and password as "admin" or blank or "password".
Set WAN settings as your internet service provider.
If you internet need user name and password for connect then you need to configure router in PPPoe mode.
Enable DHCP if you want ip address from router.
Click on wireless and enable wireless .
Enable WEP security if you want secure wi fi.Then add WEP code then save settings and router.
Then disconnect router from computer and connect internet service provider cable into it.
Then you can use it wireless.
Thanksd for using FixYa.
Jan 06, 2010 | NetGear WGR614 Wireless Router
Can't install netgear router WGR614 IN AN DELL INSPIRON1594 LAPTOP
The laptop/computer's wireless card may not have the latest wireless card driver installed or it is not enabled and working. Check Device Manager to see if is is working and enabled. I suggest you install the latest wireless card driver.
Next check the wireless card configuration, it needs to have the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 23, 2009 | NetGear WGR614 Wireless Router
Network wont show up on any Wireless Network List
Reset your router to factory defaults.
For that press RESET button for 10 seconds it is in back panel of router.
hen connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Then save settings and restart router.
Thanks.
Nov 10, 2009 | NetGear WGR614 Wireless Router
Computer is not pick up signal from router
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Jun 26, 2009 | NetGear WGR614 Wireless Router
Netgear range max cant be found by ps3 please help
Dec 24, 2008 | NetGear WGR614 Wireless Router
Netgear wireless-g router wgr614
to check the wireless settings on the router you need to do this on the main computer.(the computer that is connected physicaly on your router)
launch IE type 192.168.1.1(routers ip address, there are cases that the router has a diff IP) on the address bar, it will ask you for the username and password (by default username=admin password=password or if id doesnt work just type a normal password that you normaly used)
once your on the setup page clieck on wireless settings located on the left menu.
it has all the information that you need for the wireless and on that page you can change your security settings for wireless.
Aug 31, 2008 | NetGear WGR614 Wireless Router
I lost the installation cd for my netgear 54mbps wireless router WGR614 V6
you just need to open a web browser and type http://192.168.1.1 (default username is "admin" adn default password is "password"). it'll prompt you now for the router's setup page where you can setup your internet connection.
hope this'll help you and if you have other concern just ask me
ciao!
Jul 08, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
1,758 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
