Question about Zenith XBS344 System
Progressive Scan Mode
I recently acquired this system from a buddy and while searching and trying new options I came across the progressive scan mode feature. Being the curious man that I am, I chose that option and it immediately went to an all blue screen with the words PROGRESSIVE SCAN MODE across the screen. I have messed with it for hours, trying every button on the remote and I cannot get rid of this. I cannot watch DVD's, it simply says PROGRESSIVE SCAN MODE. It's driving me insane.
  • Anonymous Jan 05, 2009
    the only way i know to fix it is to hook it up to a tv with progresive scan.
  • anna1453 May 11, 2010
    We have tried the suggestion in the last line and it did not work. We cannot do the other two because the set up menu will not show up for us to work with. All we are receiving is Progressive scan mode and a blue screen. Please help.
Check for video out in the dvd setup menu, and set it for composite,
It may be set for component.
another thing to try is setting the the progressive scan option off in the setup menu, you wont benefit from it, but at least it might work.
if you already tried using the prog scan and your T.V isnt compatible, you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
good luck!
Posted on Jul 09, 2008
I cant watch any dvds, it says its in progressive scan mode and the screen is blue. i can hear the movie but not see it
ur dvd is in progressive scan mode. u have to get out of that setting ,because ur TV dosen't supports the progressive scan. do the following to get out of the progressive scan mode.
1. power ON the dvd.
2. press stop button to stop any disc that is playing.
3. press stop again and hold it for five seconds.
the video out will be restored to the standard settings.
Jan 13, 2011 | Zenith XBS444 System
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
The DVD is in progressive scan mode and I don't know how to get bake to normal play.
Ive heard that Holding the "stop" button down for about 5 secs solves this problem, ithink the disc has to be out as well
Nov 07, 2008 | Daewoo Televison & Video
Magnavox MDV560VR DVD/VCR combi
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
My sanyo dwm-3900 is on progressive scan mode how do i fix this
If your DVD players is set to Progressive Scan Mode, tehn ther would be a light indicating it is so. The light is labeled P?scan on the bottom right side of your display window.
You can disable/turn OFF the P/Scan mode in the "Setup menu".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
Apr 29, 2007 | Goldstar GBV241 DVD Player/VCR
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Zenith XBS344 System Logo
255 people viewed this question
Top Zenith Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
