Question about Cooktops
On Light Won't go off on cooktop
All burners turn will turn off and stop heating, but the "on light" will not go off.
  • Allen Cook Jan 30, 2008
    Sorry I left out that it is a radiant glass-top cooktop which creates an access problem. This is my first of this type so I have zero experience with them and don't know where to begin.
    Thanks!
    Problem Solver:
  • 30 Answers
I am asuming you mean a standard cook top stove.
you should probebly unplug the range because it looks like a short circuit.
!) a shorted or failing burner/control will light to ground
2) every burrner has a fuse, unscreww each burnner fuse till light goes out. that is the problem piece.
3) change heating elements with the element of the same size on the other side of the stove.
4)put fuse back in. if light off - bad elemet - if light on - bad control
bad control - I'm not sure you want to tackle that. but call me back :)
Posted on Jan 30, 2008
SOURCE: cooktop light stays on when cool
Please be more specific.
A.  What is the "plate cut-out"?
B.  How does one access it?
Posted on Oct 15, 2007
  • 619 Answers
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Posted on Jan 05, 2008
milten1
  • 1304 Answers
SOURCE: LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Posted on Oct 21, 2009
Testimonial: "THANK YOU FOR GETTING BACK WITH ME QUICKLY YOU GAVE ME SOMETHING TO CHECK FOR AND I WILL LET YOU KNOW HOW IT WORKS"
  • 221 Answers
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Posted on Jan 30, 2010
marka19
  • 1430 Answers
SOURCE: have whirlpool glass cooktop,, the
This is usually one of the switches has failed. You will need to uninstall and disassemble to acess the switches. They are easy to check and replace. Here is a link that should help http://appliancehelponline.com/infiniteswitchvideo.html You can also enter your model # for diagrams and illustrations of your specific model.
Posted on Sep 03, 2010
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
Ingiter will either fail to start burner or won't quit clicking on the 1% of the times it does start up the burner
Hi look for adjustments to the lighter and also there should be a sensor tat sees the fire , this sesor allows the main gas to turn on, but only if it feels the heat , kind of like a thermocouple , if you think about about any type problem like this: what is it not doing ? then think what could cause this >/? if you go about any repair this way there is nothing you can't fix unless you need a part !
Dec 05, 2011 | Jenn-Air JGC8430 Gas Cooktop
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Sep 09, 2017 | Jenn-Air JED8430 Electric Cooktop
My Kenmore cooktop will not heat properly, all 4 burners. They turn on and heat a little bit, but the burner on lights do not light up and the burners do not heat to full temperature. I closed my oven...
hi my name is mark, a service tech needs to check the voltage to the cook top. you will probably find improper voltage. check data plate for proper voltage should be 208v or 230v depending onwhere you live.
Feb 18, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktop will not get hot
wire conections to ct from house wiring may be loose check conectors
Dec 24, 2008 | Jenn-Air JED8430 Electric Cooktop
Whirlpool electric Cooktop's one burner not heating
Initially, it could either be:
  • open heating element (most likely);
  • open temperature limiter (least likely);
  • faulty/loose connection/wiring (a possibility).
Please confirm that it is a Whirlpool RCC3024 Electric Cooktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
Burners ignite simultaneously (clicking)
When you set a burner to light, all burners spark. This is normal. Move knob back off the spark position as soon as burner lights. All sparking will stop.
Sep 04, 2008 | DCS 48 in. CP486GDSS / CP486GDSSL /...
On light flashes
i would replace the custom control kit. elemnt usually fine that contorol kit is a new circuit board that only controls that one burner
Mar 09, 2008 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Cooktops Logo
453 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
