Question about IBM E54 15" CRT Monitor
Monitor settings; how do I change the brightness for pictures/video?
I press the menu button on my monitor, and the brightness is at 100%, but photos/videos are still quite dark. I don't know what properties and/or settings I go to to change those features. I see everything on the website fine, which is bright altogether, except for videos and photos that just happen to be dark. Please help.
Thanks,
J.B.
  • Anonymous Feb 13, 2009
    yes I have the same problem
4 Suggested Answers
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
The Joat
  • 81 Answers
SOURCE: how to unlock the screen menu
You need to press and hold the "enter" button for 10 seconds to unlock the controls for adjustment. After you have the settings where you want them you can press and hold the "enter" button again for 10 seconds to lock menuback up. This will prevent anyone from changing your settings by accident.
Posted on Jan 08, 2008
Benimur
  • 6966 Answers
SOURCE: phillips 202p4
Assuming no hardware/component fault, the dimness of a monitor signifies near end of life of the CRT (tube).
There are a few tricks/tweaks that can be done but of course these are just prolonging the inevitable. Should you want to give any of them a try, they are:
1. Adjust the Screen controller at the rear of the Flyback Transformer (FBT) to maximum effective brightness. It may also be needed to adjust the Focus control;
2. In some versions, there are sub-bright and/or Automatic Brightness Limiter (ABL) trimpots soldered direct to the PCB that can be adjusted;
3. the heater voltage can be slightly increased either by using a stepdown transformer that has multiple taps about1~2 amps. In some instances, the heater has an external loop around the core of the FBT, adding a turn or so would also serve the same;
4. adding a 100uF/160V capacitor after the diode of the FBT's output that supplies the 3 color drive transistors.
5. use the HV/anode cap of a small monochrome monitor to inject high voltage to the screen grids of the picture tube of the 22" CRT. the heater of the 22" CRT must be temporarily shorted.
All of the above require familiarity and knowledge of electronic components and circuitry, use of a soldering iron and working around high voltages.
If you are not comfortable going through this route, perhaps your best bet would be to seek the services of a qualified professional.
If your concern has not been corrected after completion of the above procedures, you may need to replace the monitor.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 15, 2008
How do you adjust brightness on a Gateway ZX4971. There are no buttons on the monitor.
My Gateway monitor instructions refer to buttons located on the right side. The procedure calls for pressing the Auto button first to set the display image for the current screen resolution then pressing the Menu button to open the on-screen display (OSD) menu. You can move through the OSD menu to select parameters such as Picture (brightness).
Dec 18, 2014 | Gateway Computers & Internet
The monitor brightness control menu remains on the desktop, on top of any other window and won't switch off.
Sounds like your button may be broken internally.
Try unplugging the power from the monitor and plugging the power back and turning the monitor on.
Does the menu pop up on its own?
If it does then your button is broken internally.
Jul 14, 2014 | ASUS Computers & Internet
Need the operation manuel for my 22inch Gateway monitor can't change operating language
I have a smaller sized Gateway monitor than yours, but I'm sure the monitor buttons (on the front) perform the same functions on all sizes.
You should have eight control buttons on the front of the bezel (as listed from left to right): source, menu, down arrow, up arrow, left arrow, right arrow, auto/set, and on/off buttons.
Press the menu button, the first dialog screen that appears (at least on mine) is the brightness/contrast function. The screen will show the function to be changed, and a very small picture of what screen you have in view.
Once the first function is listed on the screen, press the down arrow to access the other screens (color, tracking and set-up), each having their own little picture indicating what screen you are looking at.
Brightness/contrast - picture of half light, half dark circle
color - RGB picture
tracking - two squares on top on one another slightly off center
set-up- hand pointing left
You want the set-up screen which shows a picture (I think) of a little hand pointing to the left. Once you are in the set-up screen, press the auto/set button and the first line will be highlighted (usually it is the language choice).
Once highlighted, press the right arrow button until your language name appears (i.e., English, Duetsch, Francais, Espanol Italiano, -there is no choice on mine for Japanese, etc.).
Press the menu button again and that should do it.
Feb 10, 2013 | Gateway HD2201 22" LCD Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Adjust monitor
hi, most monitors have between 4 buttons or 8 to udjust picture. the 4 button MENU, PLUS, MINUS, OFF. when the menu button is pushed the screen will show a list of COLOUR, BRIGHTNESS, CONTRAST, etc,etc the plus is pressed to change the COLOUR, BRIGHTNESS, etc,etc. if you need to change the SCREEN setting BECAUSE THE ICONS ARE TOO BIG click on START go up list to CONTROL PANEL go to DISPLAY click on this and go to SETTINGS click on this and on the left. change to 1024 by 768 SCREEN SIZE (COLOUR 256). press APPLY wait press OK. gerry
Sep 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
How do I brighten the screen. It is very dark.
Okay on you monitor there is a button there you press its labeled with a little picture of a monitor with a arrow on it or in to that regard you push that button and there should be onscreen menu you use the + and - to scroll to the correct function you want once you done that you should be able to save your settings. This is all done on the monitor!
Please do click the accept button if this helps , Thanks
Nov 05, 2009 | Acer Veriton M410-UD4000C Athlon 64 X2...
COMPAQ 7500 monitor, MenuBar/Brightness Bar, Keys not working
replace Menu buttons (Microswitches) and check 5v path
check dry points.
Oct 11, 2008 | Compaq 7500 17" CRT Monitor
Acer LCD Monitor AL2671W - screen too bright!
I had the same problem with my TV when I purchased it used. Select the input you are having troubles with and enter "Service Mode" by pressing and holding the "VOL - " button and "CHAN + " buttons on the TV, simultaneously until the screen flashes red one time.
At this point you will be in service mode. Pressing the "MENU" button will open a service menu, which is different from the typical user menu. From the service menu you can further adjust your image settings until you have a decent picture.
Initially my VGA input looked terribly bright and washed out. Now it looks incredible!
Mar 04, 2008 | Acer AL2671W 26 in. LCD Television
More Brightness
on the front of the monitor there are key buttons naming menu, ok button and left & right arrow marks buttons first press menu button then go to brightness then by using arrow keys you can increase & decrease the brightness once you are finished decreasing r increasing press ok button.& there are many other settings you can change like contrast etc....
Feb 07, 2008 | LG Flatron 775FT 17" CRT Monitor
My hyundai monitor
There's a certain combination of keys you must press to restore your monitor to its factory settings (the original settings of the monitor ). The most common way is to press the up and down button together (normally beside the function/ menu button). Another way to lighten/brighten up the display is to raise the brightness settings of the monitor or by changing the contrast settings. This method enables you to customize the display of the monitor to suit your needs. If you still have the manual of the monitor, you can find instructions on how to change the settings of your monitor.
Dec 30, 2007 | Hyundai ImageQuest ImageQuest V773 17" CRT...
IBM E54 15" CRT Monitor Logo
378 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
