Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Ge frig not working some times
Our frig is getting short circuited? and we hear the clicking sound that stops most time if we press the water cup dispensor. we do not have the water dispensor hooked up. i have opened the back panels up and have found that the fan down below to not be running when there is cliking sound. have cleaned out down below with vacum and blown air. have disconnected the lines running to the circuit board and then reconnect that operate the fan. does not seem to make any difference. the fan blade operates smoothly when running. is there something going on with the circuit board? how can icheck anything more? bought the frig in 10/05 from home depot. sometimes now the frig stops working in the cooling of things. we get it going again,but this should not be happening. thanks.
  • BrokenFrige Mar 10, 2008
    Have the same exact problem as stated. I just unplugged it and plugged it back in. When I do this it works for about 1 day then starts to click again...
    Home depot junk..
  • Anonymous Jun 08, 2008
    I had the same problem twice. They changed the circuit board, then it was OK for 2 years. recently, the same problem happened again!
    It is really a piece of junk!!!
    Problem Solver:
  • 5 Answers
Contact GE and notify them of the problem. Also let them know that you have located numerous other cases of the problem online of people with the same problem. They will set up a service call and will cover the cost of the parts.
Posted on Aug 03, 2008
  • 4 Answers
Reyreryery
Posted on Jan 29, 2008
My GE Advantium microwave is beeping about 5 times every 2 minutes or so. The display says, "Keypanel Shorted. May need service. Press CLEAR to continue." Ironically, I need a working keypanel to press...
check the touch pad or control unit any short circuit in the control unit, other wise any moisture at control unit chec the circuit other wise replace the touch pad.
Jan 28, 2014 | GE Advantium SCA2000B Microwave Oven
Tip
How to calibrate a Bunn CWTF commercial coffee brewer
1. you need a 64 ounce graduated measuring cup or bucket
2. make sure the brewer is heated up to temp and the green light on the front is lit
3. open the front panel of the brewer
4. put the microswitch on the circuit board to "unlock" position
5. make sure the sprayhead is cleaned and open, the brew basket is on, and the measuring cup is in place to catch the water
6. press and hold the brew switch until the inlet solenoid clicks 3 times, then release
7. once the water level is at about 40 ounces, turn the main red switch off and let the rest of the water come out
8. if it brews short, press and hold the brew switch again until the 3 clicks, then press and release the brew switch for 2 more second of brew time (up to 5 times per brew)
9. if it brews too much, press and release the brew switch for two less seconds of brew time (up to 5 times), then press and hold the brew switch until the 3 clicks then release
10. once you get to 64 ounces, put the switch on the circuit board to lock and replace the panel
11. enjoy!
on Jan 15, 2015 | Bunn CWTF 15-APS Coffee Maker
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
When I press the 'power' button, I hear it click, but no picture comes on. I hear it click a couple more times, then it stops.
If it clicks then goes to standby, then the fault is in your power supply circuit. If the sound comes on then the fault is in the line timebase circuit. Aquick way to check the line circuit is to place the back of your hand about 1" from the screen as you switch on, you will feel the hairs on your hand standing to attention.
Feb 24, 2010 | GE 31GT740 31" TV
Hi The ice and water dispenser stopped working.
The first thing I would check is the plug eather under the plastic hinge cap on top of the door hinge or behind the grill at the bottom hinge to see if it hasn't come loose.
I would check to see if when you push the switch if there is current going to the water inlet valve located at the rear of the frig.
Shut the water off for the frig and disconect the line from the water inlet valve. Put the end of the hose into a pail and turn it on to see if you have good water flow to the valve.
If you have current (120 Volts) at the valve and still no water going through the valve, replace the inlet valve.
Dec 29, 2009 | Refrigerators
Clicking noise with my GE GSS22WGP
Your PTC relay is bad it protects the compressor from over heating and overloading. You need to replace it.
First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Mar 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Water dispenser not working all the time
I think you are correct that its the switch that the push bar hits is faulty. Try a serch on line for applince parts and enter you make etc. This should provide a break down of the part and a idea what is needed to take apart/off to get to it.
Jan 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
TFX22CR GE refrigerator TFX22CRXFWW does Not dispense ice.
I had this problem with a similar refrigerator. The problem was the slide switch burns itself especially if you slide it from ice to water while holding the glass in to get ice and water into your glass. Better to slide it to ice, press the glass in to get ice, release the glass to stop the ice, slide the switch to water, then press the glass in again to get water. I "fixed" mine by removing the control panel and soldering some of the connections on the slide switch together so that we now have no crushed ice function, but the ice cubes work again. You can also replace the circuit board in the control panel to restore it to like-new operation. I could not find a place to order just the slide switch.
Not sure if this is the same problem with your unit, but sounds the same.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Frig and feezer stopped working
It sounds like the overload and relay on the compressor.If the problem isn't that then you need a compressor.
Eeggman
Nov 07, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
