posted by dirty sensor on Jan 29, 2008
I have a hoover modeU6439900 that has a dirt finder green and red light. I am sure that this is controlled by some type of sensor. My question is where is this sensor located? I beleive that it needs to be cleaned off or replaces as the red light stays on all the time now. It was working well up untill a month ago. Can you help me with the location and or replacement?
2 Other Users Have The Same Problem
Comment by Guest, posted on May 14, 2008
have same problem with dirt senor, still have not found a solution
Comment by Guest, posted on Feb 01, 2008
I have a hoover Savvy Upright Vacuum I just changed the belt now the dirt finder leds have no signal power
Best Solution
posted on Jan 29, 2008
The sensor is located inside where the hose hooks on the back of the vacuum. Unhook the hose, looking down the duct, the will see a disk near where it curves to go into the vac. Clean that out, if it still stays on, It is called the EDF duct/mic asm. part # 47823004. The cable for it routes thru to the circ. board that is by the light. The circ. board number is 46851031. Also make sure that you don't have a clog in the hose or the inlet by the brush motor.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Hoover U6437-900 / U6439-900
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Hoover U6437-900 / U6439-900 Windtunnel...
bag lid assembly wind tunnel...
I need this bag lid assembley.... Answer This...
Belt Stretched on my Hoover...
Roller brush was turning... Answer This...
Brush Roll belt won't engage on...
I replaced both the flat belt... Answer This...
Repair Service
Find Vacuum Repairman Near You:
