Question about Gateway FPD2275W LCD Monitor
Acer 1751 widescreen monitor screen resoultion
I have an Acer 1751 widescreen monitor & cannot find the correct drivers/cannot alter the screen resoultion from 800 x 600 to higher, so everything is rediculously huge. Can you help?
  • Jon White
    Jon White May 11, 2010
    The drivers you would need are for the pc/laptop this is connected to. What Brand/Model PC are you using?
  • 43 Answers
Is the VGA card you are using onboard.If it is,purchased new Video Card e.g. 128MB.Install this unit.
When reboot,go to Control Panel>Display>Settings Tab.
Adjust as required
Posted on Feb 02, 2008
6ya staff
SOURCE:
New monitor purchased with a package with compaq desk top, but trying to use with a Acer desk top, screen comes on , but then goes completely dark after about two seconds. If switched off then on, again...
Could be a faulty monitor, or could be missing the driver information for the monitor. Usually when you first connect it will use a generic driver to start but then should automatically download and install the correct driver information for the monitor. Could also just be a faulty cable, power or VGA, HDMI, which ever you are using. Try using different cables first, then you can google search for the correct driver and manually install it.
Aug 22, 2010 | HP Compaq Q2159 21.5-Inch Widescreen LCD...
Re ACER V203H 20" monitor - appearance. Why is the image size only 16" with black margins approx 2" on left and righthand sides? I bought this monitor brandnew - thought it was widescreen. If I change...
It is definetly a widescreen the issue is either with your display card or your resolution setting you need to check both. If you would have told me wether your display is through mother board or scsi card the model of mother board or the display card then i could fix the issue easilly.
Mar 06, 2010 | Acer V203HA Monitor
Screen is stretched widescreen, cannot figure out how to alter the format
You need to set your PC Video resolution to 1366 x 768 for the native resolution of this monitor.
Jan 25, 2010 | Acer X163WB Monitor
The pictures are too wide all people look fat
You most likely have a wide screen and the screen resolution needs to be adjusted to suit the monitor.
Go to the Control Panel - Display and adjust the screen resolution until you get a normal image and correct screen aspect screen ratio. Start with a screen resolution of 1024X768 and gradually increase it until you get an image that suits your screen.
Oct 01, 2009 | Acer Computers & Internet
My photographs are distorted on my widescreen, how do I rectify?
go into the settings menu for the monitor, properties settings display, and change the resolution to the native resoultion for your monitor, iyt sounds like you arend running it at the proper resolution, also run the driver that came with or is on the website that is associated with this specific monitor, it sounds like it was never set up right
Jan 07, 2009 | LG 22" Widescreen Flat Panel LCD Monitor
New ACER 1751 monitor added
Try going into Start - Control panal - add new hardware. First let windows look for itself ;then If it doesn't find the monitor then tell it monitor and see if it will find the correct driver for it. Worth a try.
Nov 10, 2008 | Gateway FPD2275W LCD Monitor
Text ghosting on Acer 22" widescreen monitor
Hi...there,
It's seems you need to reset your WB (white blance). Open your on screen display and look for WB settings... Good lucks!
Oct 05, 2008 | Acer Computers & Internet
Distorted screen
Youre problem is because when a widescreen monitor is fed with a signal that is not ws it stretches the image sideways making people look short and fat. The only way to really fix this is to make sure the graphics card is providing a widescreen resolution to the monitor. In this case the native resolution (the resolution the screen looks best at) is 1680 x 1050 . If you right click ur desktop and go down to properties and settings u want to change the screen resolution to a widescreen res.
Hopefully 1680 x 1050 ... if this is unavailable try 1440 x 900
If you have an nvidia graphics card you can also go to the nvidia control panel and change the resolution attributes. If the widescreen res isnt available u could also try the 'change flat panel scaling' and select the do not scale option.
Please note before starting any of this make sure u have the latest graphics and monitor drivers available.
May 27, 2008 | Acer AL2016W 20" LCD Monitor
Philips game trouble
When your game first loads. Enter the games settings and adjust the screen resoultion to match your wide screen monitor. If you can't get that far than hook up that other monitor. Load the game & enter it's screen settings (display) & adjust the resoultion. Your new monitor is wide screen. Your game needs to match the wide screen as well.
Good Luck!
Mike
Mar 29, 2008 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
78 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
