Question about Canon Pixma iP6210D InkJet Photo Printer
Canon pixma MP 130 waste ink absorber
I keep getting a message that my waste ink absorber is nearly full, and it won't print. What can I do to fix it?
shguitar
  • shguitar Feb 10, 2008
    Thanks for the advise. How do I take the lower covering off? I tried to open the printer up and it is very confusing. I couldn't get it clear open.
    Genius:
  • 1,665 Answers
Hi have a look here:
http://www.printcountry.com/faq-troubleshooting-refill-kits.asp
What should I do if the printer does not print after refilling the cartridge?
  1. Step 1: Run the print-head cleaning mechanism (described in your inkjet printer's manual) and attempt to print a few pages.
  2. Step 2: If this procedure does not work, using the syringe supplied in your refill kit, inject air into the top air vent to clean the nozzles. A small amount of ink should be emitted from the nozzles upon injection. (The nozzle is the porous metal piece at the bottom of the cartridge)
  3. Step 3: If this procedure does not work your print-head nozzles are probably blocked with dried ink. At this point use the syringe to take out as much ink as possible from your cartridge and read on to the next section.
Posted on Jan 29, 2008
    Genius:
  • 3,422 Answers
Turn on your MP110.
After that press: Menu - Scan - Copy - Scan.
It will enter in Service Mode.
SERVICE MENU
NVRAM ACCESS
SET ABS-M LEVEL TO 0
OK
Then turn it OFF and again ON and there it is, as good as new.
Goodluck,
Dont forget to rate me as fixya..
    Champion:
  • 207 Answers
I suggest that you should replaced it with a new one since it is not reusable nor recycle.
  • 871 Answers
Hi there, what you need to do is physically or manually remove the lower covering of the pixma printer that serves as the waste ink abosrber, its small but youll know thats it cause of the ink there.
hope this helps.
fixya!
    Sergeant:
    Champion:
  • 226 Answers
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
  • earl llanera
    earl llanera Jan 29, 2008
    if it will not work try this one.
    1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
    2) Enter NVRAM by presing <--- or ---> then OK
    3)SET ABS-M LEVEL TO 0
    4)OK
    Hope it works for you
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Pixma MP 130/110 Printer/Copier/Scanner waste ink absorber full, It neither prints nor copies
Cleaning the waste ink pads is easy.
Are your ink tanks empty and have you been using non Canon cartridges?
Regards,
Worldvet
Aug 01, 2008 | Canon Office Equipment & Supplies
I have a Canon Pixma MP 130/110 Printer. Machine is not printing. Have been through all the recommended cleaning/ maintenance procedures several times and fitted new ink cartridges all to no avail. Message...
Pixma IP3000
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
Mar 06, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Canon 130 printer ink absorber is full. need advice to fix.
Hi, is it canon 130 or canon 1300, if it is canon 1300 you can try to fix it using a manual reset and software reset. You can visit my blog here for free reseter and tutorial:
http://feedproxy.google.com/~r/Inkq-mac/~3/eJkvGfLlL1U/how-to-reset-canon-pixma-ip-series.html
To know why "waste ink absorber is full" message appear, you can visit it here:
http://feedproxy.google.com/~r/Inkq-mac/~3/0DgDreiMUw8/waste-ink-absorber-is-full.html
If the reseter won't help you please let me know. Hope this help.
Dec 22, 2009 | Canon Office Equipment & Supplies
My Canon Pixma MP 170 tells methe waste ink absorber is full...
It is a shop repair since you have to use Canon diagnostics to reset the count and clear the error. The new part is around $10.00 only.
Jul 01, 2009 | Office Equipment & Supplies
MP 450...Waste Ink Absorber Full..Does not print
1.Go to: http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
2. Menu 1, select "Multifunction"
3. Menu 2, select "Inkjet"
4. Menu 3, select "PIXMA MP450"
5. Click the "Go" button.
6. Under "Search Our KnowledgeBase", type: "Waste Ink Absorber Full"
7. Click the "Search" button
8. In the search results, select "1. ');includeTableSubmitItem(12835, 'ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. '); return false;" class="midredlink">ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>"
9. In the next page, select "1. Ink absorber replacement options - MP450". A page will be displayed describing how to fix this problem.
May 16, 2009 | Canon Pixma MP450 All-In-One InkJet...
Ink absorber is full
You would need to take it to a canon service centre..
Or look on ebay, i thinks its just cotton wool type wadding thats in there but i dont know exactly where it would be inside the printer.
Plus for the same of about £15 if anything goes wrong they have to fix it.
Jan 20, 2009 | Canon PIXMA MP150 All-In-One InkJet...
WASTE INK NEAR FULL
Use paper towls and absorbe the ink out of the waste ink tray.
Dec 23, 2008 | Canon Pixma MP450 All-In-One InkJet...
Waste ink absorber is almost full
Try this:
Resetting overflow error code for Printer Canon Pixma MP110
  1. Turn on the printer.
  2. Click Menu, and then Scan, Copy and Scan again. All - entered the service mode.
  3. Select Counter
  4. Click Copy - everything. Waste dropped to zero.
  5. Turn off the printer POWER button.
Good luck
Oct 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Canon Pixma iP6210D InkJet Photo Printer Logo
87 people viewed this question
old marine
old marine
