The water supply line is a small 1/4" tubing (soft copper or milky-white plastic) and uses a compression fitting. That is normal. You can go to most any hardware store and get a kit for connecting the icemaker. The kit has the tubing with fittings, and a piercing saddle valve you install on a COLD water line to supply cold water to the unit. If plumbing is not your strong point, please seek help. Although it is pretty straight forward, it can be a little tricky.
