Question about RCA RP5020 Digital Voice Recorder
Framesize is negative value
When I go to copy and past I receive a message that reads:
Framesize is negative value.
I will not let me delete file either.
  • 2 more comments
  • paulc7883 Sep 14, 2008
    When I try to make the VOC file to exe file, a Warning Decoding window will say "Framesize is negative value". I cannot copy the file to anywhere. I get a message "Cannot copy A00000??: the file or directory is corrupted and unreadable". The model of the voice record is RCA RP5022B.
  • Anonymous Nov 29, 2008
    RP5022B also.
  • Anonymous Jan 27, 2009
  • Ali Nichole Oct 15, 2009
    How would you fix this problem with Windows Vista? I don't have Windows XP.
Here is something that has worked for me when nothing else would.
In Win XP, right click on the drive letter for the RCA DVR and select properties, tools, error checking. Click the "Check Now" button. Check both the "Automatically fix file system errors" and the "Scan for and attempt recovery of bad sectors" boxes. Then Start.
Usually, my file is repaired completely with no losses, but once in a while I end up losing segments of the audio. But having some is better than none.
Lastly, when I run into a problem like this, I always make it a point to reformat the drive after I salvage the files. If you don't, more files will get trashed in the future.
I hope this helps someone. Pass it on or post/link it to other sites.
Posted on Apr 25, 2009
My RCA recorder gives me a framesize is negative value message when I try to download it to the RCA digital voice manager
Posted on Sep 14, 2009
2 Suggested Answers
SOURCE: Framesize is negative value
All I can say is, get used to it. Customer support will be of no help, at all. They;ll advise you to reformat, whcih will delete everything and does nto solve the problem. Then they will tell you to check your compatibility settings, which doesn't solve anything. I have this recorder, actually two of them and my brother in law has one. Two of them work fine, the toher does not. Sometimes it worls sometimes it doesn't. I wrote to support and told them I had reformatted numerous times without it helping. Guess what they said when they wrote back? They gave me instructions on how to reformat. They said I should backup my files so i would nto lsoe them. Well, I can't back them up if I can't get them off the recorder....I've ran into numerous people with the same problems and the same stories abotu customer support. SOme of the complaints date back over a year.
Posted on Apr 06, 2008
How to Copy or paste text while inputting or reading?
I am not familiar with this phone... Is it touch screen?
Jun 02, 2014 | Cell Phones
' file integrity violated' error message.. copy problem
A message display as file integrity violated display when i try to copy or move the file
Jul 23, 2009 | SanDisk CompactFlash PCMCIA Adapter
Files are saved to a CD for backup but will not open after they have been burned to the CD. Error message reads "You do not have sufficient permissions to the specified folder. To use QuickBooks in a...
The files are set to read only on the CD. If you would like to open them, please copy / paste the files to your PC and open them from there.
To rectify this in the future, please set the file permissions on the files before you burn them, and remoce the Read Only attribute.
Jun 24, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Files disappeared from maxtor one touch iii mini
Alrighty, I finally found the handy file undelete utility which I have successfully used in the past to undelete files on flash cards. The file is Restoration.exe, and it doesn't use an installer. Thus it is a completely stand-alone program. The author of this program says that it is compatible with all Windows OS through XP. It probably will work with Vista too. The program also is compatible with NTFS as well as FAT32 file systems. Here is a link to CNET.com where you can download it and then use it to try to recover the deleted files on your flash card:
Restoration
Once you have recovered the files on your flash card, copy and paste them to your hard disk. I never do cut and pastes from flash cards for fear of accidentally losing files. Copy and paste, and once you have verified that the files were successfully copied to your hard disk, then delete the files on your flash card if that is your preferred method. Yet I prefer to put the flash card back in my camera and then do a quick format of the card in order to delete all files on the flash card.
Anyway, hopefully this restoration utility will allow you to get those deleted images back. :-)
Apr 13, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
RCA Digital Voice Manager software for RP5120 "warning decoding"
Bad News... I spoke to AudioVox/RCA (800-894-0956 < Direct DVR Number) and they told me that once you get this notification of a bad file format, there is NOTHING that can be done.
I tried DOS, too. Nothing worked.
The only thing left to try is connecting the recorder to the computer via a cable from the line out of the DVR to the line in of the audio card, and record from there. I'm going to try this, then return the recorder, if possible. Mind you, I've gone through several of these recorders and all of them have had this problem... eventually.
The customer service person there at AudioVox/RCA was direct, helpful, but clear that I couldn't do anything but reformat the recorder. Though she didn't really seem to care, by her tone, one way or another. They were still reproducing this product even with the flaws that exist (they certainly did not take ownership of the problem... they said it was out of their control and the problem was just like a virus).
Mar 16, 2009 | RCA RP5012 Digital Voice Recorder
Mar 09, 2008 | RCA RP5020 Digital Voice Recorder
Can't copy files to and from Windows Media Player
If the music service subscription that you originally used to transfer these files has expired, then you will get this error message.
Also, you have to fully resynchronize to the original computer yo connected the player to every 30 days.
Mar 08, 2008 | SanDisk Sansa e250 MP3 Player
RCA voice recorder problem
Same problem. I'm going to return mine and make sure I do negative advertising for RCA.
Sep 06, 2007 | RCA RP5012 Digital Voice Recorder
RCA RP5020 Digital Voice Recorder Logo
578 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
