Question about HP Officejet 7210 All-In-One InkJet Printer
Won't come on after pushing power button
Seems it just stopped working. I can't find manual to see if it has an internal fuse or something....ever had this type of problem.
  • ImDGilbert Feb 05, 2008
    This is great information to know for future reference...it just so happened that the particular outlet in my surge protector had burned out. Plugged into a new outlet and is working fine...Thanks for responding
  • Anonymous Mar 17, 2009
    I have the same problem but, the above didnt work for me.
    All Im looking for is the Service Manual for Officejet 7210.
    Can you help?
  • 16 Answers
Try to check if the power outlet you are using is fine. If its in good condition, try pulling the power cord at the back of the printer and at the wall outlet for 30 secs. Plug it back in and make sure to press the power button completely. If it still wont work, try to do a semi-full reset y following the steps below:
unplug the printer
press the # and 6 keys on the printer simultaneously
insert the power cord back without releasing those buttons
turn on the printer
if its still the same then i think your printer needs to be replace. Call 1-800-474-6836 to replace your printer if you are still in warranty
Posted on Feb 01, 2008
My sony kds 60a2020 won't come on. When I push the
That is a error code and in several of these sets it means thermal fuse is blown--Google the model number with owner manual or service manual to learn for sure.
Jun 07, 2012 | Sony Televison & Video
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
My Viewsonic N2630W just stopped working. Tried different power cords but it just seems to be bricked. Is there a fuse or something in it?
I have the same problem....one day it was working, then nothing. no light when you push the power button. Its got power...just wont come on. Saw somewhere that it could be a bad capacitor on the power board...which is way beyond what I am able to do. Was hoping for a simply fuse fix.
Jul 24, 2011 | ViewSonic N2630w 26 in. LCD TV
Denon AVR-687 cannot power on, no power light lit around power
Check the main power switch next to the large power button. It is a small push button. If it is pressed in and you still have no light around the power button then very likely you have a dead power supply.
Apr 27, 2010 | Denon AVR-687
Power Light on but will not start cycle
Usually Whirlpool dishwashers have a reset code which is pushing the buttons on your dishwasher such as push heat dry, then normal, then heat dry, then normal, within 5 seconds - so push them fast and in that order and wait. It may take a couple of minutes but should reset. If that isn't it, it may be the pump motor not working properly. Also look down into the bottom of the dishwasher and make sure something isn't stuck down into the drain such as a broken piece of glass or a fork. Is there water still in the bottom? It may not be draining so that would suggest it is stopped up. It could be the keyboard but showing power it seems less likely. I don't think it would be the thermal fuse because that usually stops everything including the power light.
Apr 08, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Power windows won t work
MY POWER WINDOWS WOULD WORK AND THEN NOT WORK, IT SEEMED TO BE WHEN I WOULD SHUT THE DOOOR THEN THEY WOULD WORK, THEN CLOSE THE DOOR AGAIN AND THEN THEY WOULD QUIT AGAIN. THEY ALL STOPPED WORKING AT THE SAME TIME, IT SEEMS TO HAVE SOMETHING TO DO WITH THE DRIVERS SIDE DOOR. NOW THEY WON'T WORK AT ALL.
Apr 15, 2009 | 1995 Jeep Grand Cherokee
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
HP Officejet 7210 All-In-One InkJet Printer Logo
364 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
