Question about Dell 3100cn Laser Printer
Toner install error
I repeatedly get 093-943 toner install errors telling me to re-install the black toner. This usually occurs at the end of a printing job, after calibrating. Occasional it happens in the middle of a job after printing graphics. Opening and closing the front panel always clears it, without even touching the toner. I am using only Dell toner cartridges, and this only happens with black. This has happened with the last two black toner cartridges I've used. Dell says the fault is the toner cartridge, and has replaced a couple at no charge, but it continues with the replacement cartridge. Thanks for any advice.
  • 6 more comments
  • oldgray Jan 29, 2008
    Solution does not address the problem.
    You have just restated the problem.
    Firmware is up to date, toner is installed correctly, lid latch is fine.
    This is a Dell 3100cn, not an HP LaserJet 2400.
    No USB cable, the printer is on a network.
    The link you sent is about imaging drum problems. I don't have an imaging drum problem. I've replaced the imaging drum once, and got the expected capacity out of it.
  • oldgray Jan 30, 2008
    These solutions were not helpful. I have read all the Dell troubleshooting documentation before posting the problem, none of the suggested sources had any relevant information. One solution regarded the wrong printer, another solution involved the imaging drum design which is not the problem here.
    I don't think you read the comments, the printer is not connected to the computer, it is on a network. The problem is clearly a hardware issue rather than a driver issue. The problem occurs regardless of which computer prints. Furthermore, a different identical printer does not have the problem with any of the computers that use my printer.
    Genius:
  • 1,226 Answers
Ok you should unplug the printer out to the computer and then reinstall the driver of your printer because setting on the printer will apprently detecting false message. it is better to uninstall the driver and restart and then reinstall it again.
Do not connect the printer when installing the software. wait for the computer prompted you to connect. thank you may this help.
Posted on Jan 30, 2008
    Sergeant:
    Champion:
  • 226 Answers
    Genius:
  • 3,422 Answers
the first thing is check this site for eror codes:
http://www.office.xerox.com/userdoc/P750/resource/750-66.html
The message “Install Cartridge” from the HP LaserJet 2400 Series Service Manual does not indicate anything other than reinstall or replace the print cartridge, which you already did without success. We interpret this as a false message, leading us to question how the machine senses a cartridge, installed or not. The mechanism lies behind the left side cover. To remove the left cover, first remove two black panhead screws in the handhold at the base of the cover.
Open the cartridge door and rear cover. Release the plastic tab at the top, rear corner of the left side cover from inside the rear cover.
Turn the printer on its right side and release two plastic tabs on the bottom of the left side cover.
Pull the rear of the left side cover out and away from the machine. Next, shift the cover forward off the tabs along its front edge.
Goodluck,
Dont forget to rate me as fixya..
Posted on Jan 29, 2008
  • Priya darshan Jan 29, 2008
    You can even check this link.
    Click here
    hmm..
    Check this link out.Im sure this will solve ur problem..
    Click here
  • 871 Answers
All i can say is that if they keep replacing the cartridge, then the problem lies with the receiver of the cartridge. as long as the replacement cartridge is there and the problem keeps on coming back, there will always be errors.
fixya!
    Genius:
  • 1,067 Answers
They could be a knows fulty black toners for these do u have all latest software is ther firmware update for the machine avb tonner droped in very well instaled lid latch broke
  • 4 more comments
  • nick helpap
    nick helpap Jan 29, 2008
    ok let me cheak sum more sol for u then give me a min please thx nick
  • nick helpap
    what about new usb cable sum older cables have issues
  • nick helpap
    http://reviews.dell.com/2341/310-5732/re...
    sound like del dont tel l u whats up everone else has same issue its bad setup deshin in this model and ther is no fix once it goes bad u need a new machine pp tryed to fix it no luck
  • nick helpap
    ya network usb dont matter insternal drum problem on the deshin on this unit ever one who owns one has problems within 6 mo
  • nick helpap
    nick helpap Jan 30, 2008
    well i told u whats wrong bad desighn they even talk about it in engenerr forums on line ok bad unit i would replace u can keep on changeing toners but wont do nothing even with new bractes on it new hatch still wont cuse of deighn should be recalled ok sorry
  • nick helpap
    they even called dell dell dont even know
Dell printer 1250c , printer in Error state
The indicators provide information on the status of the printer and help you locate each problem. Following are the Indicator Status Condition and what they signify.
  • Jam Orange on A paper jam occurred.
  • Orange blinks The rear cover is open.
  • Toner Orange on The specified toner cartridge is empty or not installed when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • Orange blinks The specified toner is low when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • All toner indicators blink when the printer is in the non-Dell toner mode (Non-Dell Toner is set to On).
  • Error Orange on A fatal error occurred.
  • Orange blinks An error occurred.
  • Ready/Data Green on The printer is ready to print.
  • Green blinks The printer is processing or printing.
  • Orange on The printer is in the power saver mode.
  • Orange blinks The printer is canceling.
  • Start Green on To continue printing, press the (Start) button.
  • Cancel - To cancel the current job or clear the error, press the (Cancel) button.
For detailed information, please click on the link below for Manuals & Documents for the Dell Printer 1250C. Check Chapter 11 - Page 69 to 77.
http://dell.to/1at80gm
Feb 24, 2017 | Dell Office Equipment & Supplies
Red light
Error Red On
• The cover is open. Close the cover.
• There is no paper in the tray. Load paper in the tray.
• The printer has stopped printing due to a major error.
• The toner cartridge is not installed. Install the toner cartridge.
• Your system has some problems. If this problem occurs, contact your service representative.
• The toner is totally exhausted. Remove the old toner cartridge and install a new one.
Error Red Blinking
• A minor error is occurring and the printer is waiting for the error to be cleared. When the problem is cleared, the printer resumes printing.
• The toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner.
Aug 03, 2011 | Samsung ML-2851ND Laser Printer
I have an HP 3800 color laser printer. I installed a refurbished toner cartridge today and received a "49.2F05 Service Error" on its display after it completed self calibration. I am assuming it...
A critical firmware error has occurred.
1. Turn the printer off and then on.
2. Try printing a job from a different program. If the job prints, try printing a different file from the original program. If the message appears only with a certain program or print job, contact the software vendor for assistance.
3. If the message persists with different programs and print jobs, disconnect all of the printer cables that connect to the network or the computer.
4. Turn the printer off.
5. Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in the lower slot J1).
6. Remove the printer EIO card.
7. Turn the printer on.
8. If the error does not persist, install each DIMM and EIO device one at a time. Turn the printer off and then on again after installing each device.
9. Replace DIMMs and EIO devices as necessary.
10. Reconnect all of the printer cables.
11. If the error persists, replace the firmware DIMM.
12. Replace the formatter and calibrate the printer.
Jul 16, 2011 | Office Equipment & Supplies
Brand new lexmark printer, toner and cartridges installed, but get error 32 unsupported black cartridge error -tried updating drivers on lexmark site -tried taking cartridge out and reinstaling...
You could find the root cause by performing different steps. One of the easiest methods is that you need to make sure that the plastic protective tape which is usually used on the new black cartridge is off. Usually the user makes this mistake. This mistake might occurs due to absent-mindedness. The reason could also be some distractions which happen while loading the new black ink cartridge.
Nov 17, 2010 | Lexmark C546DTN COLOR LASER PRINTER ...
We have an HP 2015n printer with an error code of 10.1000. Can you please tell me what this code means? Thanks
10.1000 Black e-label missing error Error message 10.1000 supply error alternates with Reinstall c00381084.jpg with a ? under the Black print cartridge gas gauge Description The black print cartridge or print cartridge e-label is missing. Action
  1. Install the black print cartridge.
NOTE: If this error occurs upon initial power-up on the printer, remove all cartridges to check for the orange packing tape. If present, remove it before reinstalling the toners.
Nov 10, 2010 | Computers & Internet
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Toner end life
it is printing with this blinking or not?
Jan 04, 2008 | Samsung ML-2510 Laser Printer
System Fault
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Jan 29, 2007 | Xerox DocuColor 12 Printer
Dell 3100cn Laser Printer Logo
351 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
