Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Brother mfc-440cn How do you print a mirror image on t-shirt transfer paper
  • 832 Answers
By uesing a special software.
The mfc cant print any mirrow images by itself.
But why do you need to print a mirrow? as far as I remember is the print straight right thru. The foil has to be turned onto the shirt before you run the iron?!!!
Posted on Jan 29, 2008
Can HP Officejet 5740 print mirror image onto transfer paper?
Most printers don't do well with t-shirt transfer check HP web site for spec's on your machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 21, 2015 | Office Equipment & Supplies
How do I print a mirror image from canon pixma MG5250 mirror image?
In the printer driver settings, where you can select the paper type, you have to choose "other paper" and select "T-Shirt Transfer".
Jul 18, 2014 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
Print in mirror image mfc 490cw
You go to the print property and select the options.
Jul 24, 2012 | Brother MFC 490cw Color Inkjet...
"UNABLE TO PRINT 50" appears
Error: -------- Unable to Print XX
Problem: ------------ The machine has a mechanical problem. -OR- A foreign objects such as a clip or ripped paper is in the machine.
Solution: ------------- Open the scanner cover and remove any foreign objects inside the machine. If the error message continues, do one of the following: ?? (MFC-440CN only) See Transferring your faxes or Fax Journal report on page 139 before disconnecting the machine so you will not lose any important messages. Then, disconnect the machine from the power for several minutes and then reconnect it. ??
May 22, 2011 | Brother MultiFunction Center MFC-440CN...
Brother MFC-440CN printer will not see new cartridge
Your print-heads, which take the ink, and spray it onto the paper, have become "clogged". Run a "print-head-cleaning-cycle" to try to unclog those jets.
Nov 26, 2010 | Brother MFC-440CN InkJet Printer
Brother mfc-440cn printer printing crooked
There is the possibility that the scanner assembly has jumped a tooth on the drive belt on one side so the scanner is just slightly crooked. To correct this the scanner assembly would have to be taken apart enough to correctly line the assembly back up. I wouldn't recommend that you try this yourself unless you have some experience at this sort of thing. Contact Brother for an authorized repair center near you for assistance.
Sep 04, 2009 | Brother MultiFunction Center MFC-440CN...
How print iron on transfers
Yes, you need to "MIRROR" the image. Go to printer properties and select the ADVANCED TAB. Click on the MIRROR setting then print onto the transfer paper. The image should print out backwards like you are looking at it in a mirror. When you iron it onto a shirt, it will come out correct.
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing dark tshirt transfers - can't override the flipped image
Hello I think I can help you. I Would not use T shirt transfer when you make up your print I would select poster print or any other form that does not automatically reverse the image. The reason your software is designed to do this is on the regular transfer paper your laying the image down on the shirt, so for it to come out right it has to be reversed. With the dark T shirt transfer paper your peeling off the backing and putting the image face up on the T Shirt.
Dec 23, 2008 | Canon i80 InkJet Printer
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Printing to memorex cd lable paper
the paper feeder cant grip the back side of the paper. It slip through the feeder and the positioning led control cant adjust the correct positioning for printing!
Try another brand of paper!
Jan 18, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
229 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
