Question about RCA DRC8052N DVD Recorder
Split screen I have a split screen with black lines running thru the entire screen. The line in the center is larger, and they are black
  • RebeccaG Feb 11, 2008
    Mine does the same thing. Any attempts to access the menu or options is as fuzzy as the picture and we can't read it.
  • 25 Answers
Interference in the wallsocket, try plug the unit in separate outlet! if nothing happen you're dvd have leak capacitor on the power supply board to filter the interference!
Posted on May 14, 2008
Line going thru scanned document left of center.
clean the slit glass the one which is next to the large glass
Jan 10, 2014 | Konica Minolta Bizhub 362 Copier
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Panasonic plasma 1 solid black vertical line left of center
faint chance here, the larger or thicker the line the worse it is. Usually this is a defect inside the panel where it cannot be gotten at---rarely this will be a plug or connection outside of the panel.
The screen unit or display panel costs more than the set did new.
Sep 01, 2012 | Panasonic Televison & Video
73' Mitsubishi has magenta splotches moving around screen and eventually getting larger until whole screen is covered.
bad main digital board. It's the bottom board on the left, try Encompas Parts to get digital board.
Nov 27, 2011 | Televison & Video
How do you add freon to a mitsubishi split system
If its R22 you have to have a license to buy it. But outside unit on the larger copper line will be an access will look like a 3/8 copper fitting with a cap on it there is also one on the small line. You will need a tank of r22 and a set of gauges. If the compressor is running you add freon til the large copper line starts to sweat. The small line (high side) should not slug or have the gage on it jump this means its overful or has air contamination in it. Always add thru the larger line.good luck
Aug 12, 2010 | Mitsubishi Heating & Cooling
When sending a fax, black lines runs thru entire fax, what to do?
Clean off the glass where the paper runs through.You have some dirt or other substance that is blocking the light for copying or faxing.
Apr 20, 2009 | Canon PIXMA MX310 All-In-One Printer
Black lines going across the screen.
POWER SMOOTHING CAPACITORS ARE FAULTY.
CAN YOU CHECK THE CIRCUIT.
OR IT CAN BE OCCURE BECAUSE OF SIGNAL OVERLOADING ,(BAD RF STAGE)
OR BAD VERTICAL AMP.
NUWAN.
Jan 15, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
RCA DRC8052N DVD Recorder Logo
220 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
